97 C230 guages stopped after car wash - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-23-2012, 08:06 AM Thread Starter
Date registered: Sep 2012
My speed-o-meter, fuel gauge and temperature gauge and tach stopped after a car wash. I checked the fuses under the hood and when I turned on the headlights they started working, but the next time I cranked the car they were not working. I still have lights there and the clock, odometer and trip gauge still works. Any ideas? Everything digital works, it is just all the gauges with arms have stopped. Also the light in my A/C, Heat unit doesn't come on even though the unit works fine.
jimbo2869 is offline
post #2 of 5 (permalink) Old 09-23-2012, 11:49 AM
Date registered: Jun 2010
Vehicle: 1966 MB 200; Porsche 914 (6); Porsche 914 (Chev 350); 36 ford
Quoted: 19 Post(s)
sounds like a bad ground. Look for contamination, especially around ground nodes.
-- brett
bfrymire is offline
post #3 of 5 (permalink) Old 09-23-2012, 06:49 PM Thread Starter
where would I find the ground nodes?
post #4 of 5 (permalink) Old 09-23-2012, 08:24 PM
wbain's Avatar
Date registered: Dec 2003
You might try this forum:
W202 C-Class - Benzworld.org - Mercedes-Benz Discussion Forum
wbain is offline
post #5 of 5 (permalink) Old 09-26-2012, 05:38 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
It could be coincidental, never underestimate the power of coincidence to really make you work hard! Try pushing the cluster inwards to be sure it's seating properly in the connector, maybe some random movement of the car wash caused it to slip just enough to not connect/ground.
The ground nodes are anywhere you see a ground wire terminate, just check all that you can find for instruments, fuse boxes and battery, clean, unbolt and rebolt (with battery disconnected of course) and see if that helps. Unlikely but I know the W202 is sensitive to a weak battery and symptoms will slowly pile up, so test your battery as well just so you can exclude it as a possibility. Many have be confounded only to fix their problem with a new battery.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
