how do i polish these aluminum trims on my w107 and w126?? i tried everything - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 09-08-2012, 03:56 PM Thread Starter
romeo8426's Avatar
Date registered: Oct 2010
Vehicle: 1985 500sel konig special widebody, 1979 slc, 1992 300sl
Quoted: 11 Post(s)
Send a message via AIM to romeo8426
hi, thanks for the reply, i noticed you also have a w126 model. in an earlier post, someone mention that these aluminum parts are anodized, makes sense they have a coating which is annoying to work with, someone told to soak with drain cleaner first, then sand, then polish. last week i bought some rouge from harbor freight, didn't work. i guess its because i didn't use the aluminum brighter? the best results i've had, not great but ok was with flitz metal polish. does the brighter remove the anodize?
romeo8426 is offline
post #12 of 16 (permalink) Old 09-08-2012, 04:00 PM
Always Remembered RIP
Date registered: Aug 2012
Vehicle: 1990 560sec
did you use a rouge wheel and a high speed grinder?speed is what you need,but be careful you can ruin paint and parts thin parts heat up fast .no good for paint or rubber so keep an eyw on that
jumper617 is offline
post #13 of 16 (permalink) Old 09-08-2012, 04:17 PM Thread Starter
romeo8426's Avatar
Quoted: 11 Post(s)
i used a 3 inch wheel that came with the rouge with an electric drill, i have to go back and pick up the right wheel. my cars need to be repainted so i figured ill shine up the pieces first...
post #14 of 16 (permalink) Old 09-08-2012, 04:56 PM
give it a try,if you get stuck shout out ,good luck
post #15 of 16 (permalink) Old 09-10-2012, 02:48 PM Thread Starter
romeo8426's Avatar
Quoted: 11 Post(s)
hey, still looking around for the aluminum brightener. did some research and found that omega ab-55 might be the best. you can youtube it.
post #16 of 16 (permalink) Old 09-10-2012, 03:21 PM
go to your local truckstop,they will have everything you need to polish alum.alot of alum on big trucks,wheels ,fuel tanks,etc.flying J,pilot,petro,they will all have a supply,if you can find a 4"high speed gringer and use it instead of the drill,you'll never get it done with a drill motor not enough speed.
