1970 250 - Hesitation and Stalling - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-04-2012, 03:34 PM Thread Starter
Date registered: Sep 2012
We recently purchased a 1970 250 and after repeated attempts at the local MB dealership, we have been unable to cure a hesitation/stalling that occurs when the engine is cold. The car also shakes a lot when in neutral - again, when cold. Any ideas on what I should tell the repair guys to inspect/tune?
Rory
rgrewar is offline
post #2 of 3 (permalink) Old 09-05-2012, 06:34 AM
wbain's Avatar
Date registered: Dec 2003
The carbs could be warped internally and have a vacuum leak. Check the engine and trans mounts as they could be collapsed and the front flex disc. Make sure the front driveshaft coupling is greased, if it needs it.
As always, check the basics, plugs, wires, points, condenser, etc.
wbain is offline
post #3 of 3 (permalink) Old 09-05-2012, 07:22 PM
Date registered: Aug 2012
Merc 1970 250 stalling problems
Some tips right here on this forum
http://www.benzworld.org/forums/vint...-stalling.html
http://www.benzworld.org/forums/new-...-stalling.html
Hope that helps
Siliezar is offline
