1979 220D Radio Wiring - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-02-2012, 06:22 PM Thread Starter
Date registered: Sep 2012
Hello all!
I offered myself to install a second-hand radio I had lying around at home on an old 220D of a friend of mine (since her old battered radio was dead). But I got thoroughly confused with the wiring inside.
Is there any schematics that can tell me which colored wire does what? Or anyone reading this knows it by heart that can shed me some light?
Thank you in advance!
mrwho is offline
post #2 of 2 (permalink) Old 09-03-2012, 06:22 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Is it really a 1979 220D?
If so, it is a W123 model.
The car could or could not be wired for a radio at the factory. That makes it difficult to know which colours the wires have.
The easier route is to do some measurements with the aid of a multimeter.
For the radio there are one or two power wires: one with a permanent 12V and one with 12V depending on ignition lock position. The ground is usually through the harness, but a seperate ground wire can be made. The permanent 12V is usually spliced from the hazard light switch, the acc. 12V can be acquired from the cigar lighter. You can also run wires directly from the fuse box. Old radio's require one power wire, newer electronic ones two.
Apart from the power wires there are four wires for the two speakers.
Govert70227 is offline
