Fog lights - Page 2 - Mercedes-Benz Forum
post #11 of 27 (permalink) Old 08-16-2012, 07:04 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D, 1988 300SEL, 1991 300TE
Quoted: 2 Post(s)
Originally Posted by Scoot View Post
I've been wanting to do the same sort of thing but haven't found a suitable paint. Finally I ordered CRC Zinc-It because it is more heat resistant, but I haven't tried it yet. I would appreciate it if you could provide the details of the paint you used. I have not seen aluminum paint before...
thanks
Scott
Scott - OK it wasn't aluminum it was chrome (and not really chrome either I suppose). It was Zynolyte super chrome - epoxy chrome finish which says on the can "a unique formulation providing a brilliant chrome like finish..." and specifically the can said "Recommended for use on cars."
As you can see from the photos it is shiny and very reflective but not at all mirror like as you might expect from chrome (or course if there were a spray product that would give you a polished chrome finish it would be called "Miracle")
But this is a year old now - many hours of use and it is holding up great.
frankflynn is offline
post #12 of 27 (permalink) Old 08-16-2012, 09:25 PM Thread Starter
Syria Bari's Avatar
Date registered: Mar 2012
Vehicle: 1970 250 c
Thanks for the info. I now need to replace the lens for the fog light. can anyone help with this?
Sent from my VM670 using AutoGuide.Com Free App
ID:	462481   Click image for larger version
Syria Bari is offline
post #13 of 27 (permalink) Old 08-16-2012, 09:56 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 135 Post(s)
The manufacturer's website is amazingly useless - it doesn't show the part of the label with the instructions, and the tech sheet and env sheet neither one indicate the temperature range in which it can be used after dry...
Zynolyte Super Metal :: Paints and Coatings :: Industrial, Maintenance, and Construction Chemical Products :: Aervoe Industries Inc.
Looks like an interesting product. I may need to do some testing. Thanks for looking it up and posting it.
Scott
Scoot is offline
post #14 of 27 (permalink) Old 08-16-2012, 09:56 PM
Scoot's Avatar
Quoted: 135 Post(s)
What is wrong with your foglight lens? It looks OK in the picture...
Scoot is offline
post #15 of 27 (permalink) Old 08-16-2012, 10:28 PM
frankflynn's Avatar
Quoted: 2 Post(s)
How bad is yours - it looks good in the photo - or is the good one you want to match?
I found my new lens by continually searching the internet. try this guy
Hella 138mm, Online Shop OldtimergarageGR - looks like he wants 16 swiss Franc (about $16 us but there's shipping)
I've since seen these on ebay (you'll probably need to buy the whole light) pairs are way more expensive than twice a single light. You want to search on "Hella 11145"
I'll give you my old one - free + shipping (but remember it has a hole in it - you could probably patch it with clear silicon calk) as a temporary solution until you find a better one. Send me a private note if interested.
post #16 of 27 (permalink) Old 08-17-2012, 09:33 AM
Scoot's Avatar
Quoted: 135 Post(s)
As a datapoint, I think that I would sell lenses for around $45 when I had them on ebay. I don't do it anymore because I have way more foglight bodies than lenses and reflectors.
Scoot is offline
post #17 of 27 (permalink) Old 08-17-2012, 10:13 PM Thread Starter
Syria Bari's Avatar
Vehicle: 1970 250 c
The photo I posted is my other fog lamp. I need the unit that holds the lens. (the back and lens). It came off at some point. All that is left is the frame that is mounted on the car.
post #18 of 27 (permalink) Old 08-17-2012, 10:17 PM Thread Starter
Syria Bari's Avatar
Vehicle: 1970 250 c
More pics.
ID:	462640   Click image for larger version
post #19 of 27 (permalink) Old 08-18-2012, 12:48 AM Thread Starter
Syria Bari's Avatar
Vehicle: 1970 250 c
I would also like to know how to turn the fog lights on? Is there a switch or knob to turn them on?
I have had the car for a short while and
still getting to know all there is to know.
post #20 of 27 (permalink) Old 08-18-2012, 09:40 AM
frankflynn's Avatar
Quoted: 2 Post(s)
Easy - turn the headlights on (turn the switch clockwise 2 clicks) then pull the switch out 1 click. Note: the foglights will only come on with the headlights on. Also be sure that the wire from your missing fog light will not short out to anything.
You can pull the switch out a second click which would be wired to a third, red fog light in the rear (Europe only option - in fact I don't know if MB offered this or it was strictly 3rd party)
Another detail about your headlight switch - from off you can turn it counter clockwise 2 clicks - this turns on the right (first click) and then the left (second click) parking lights (a light in the tail light and under the headlight) for visibility if you parked somewhere sticking into the street. This only come on if the key is turned off. And although it seems like a cool idea you probably don't want to leave these on all night (maybe with LED lights which use way less power).
Personally I'm considering wiring the fog lights to come on as daytime running lights - shouldn't be too hard and it's probably safer but it not stock.
Frank
