1071 220D lift pump more info - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-24-2012, 08:25 AM Thread Starter
Date registered: Aug 2011
Vehicle: MB 220D/8
I now have fixed the leak on the lift pump - I found that the temporary o ring my friend installed was ok but did not stop the leak completely - eventually got a new o ring from MB dealer - the part number is:
005-997-47-45 it is a VE seal ring which I guess is somewhat different to a regular o ring you get elsewhere. Removed the banjo fitting and then remove the lower fitting which screws into the pump itself - inside you will find the o ring sits in a groove near the top - remove and clean out the old o ring and install - I just tightened down firmly - put banjo fitting on with new copper crush washers and tightened down firmly - so far not a drip from it!
Its pretty tight in there but with the help of a stubby adjustable wrench was able to get job done with only one bleeding finger - you might find a crows foot wrench (bottom fitting is 22mm) a lot easier.
Lee
Britcheflee is offline
