Replacement antenna for my 74 115 230.. - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-17-2012, 04:22 PM Thread Starter
tedg's Avatar
Date registered: Jan 2012
Vehicle: MERCEDES BENZ 230 W115 1974
I am trying to replace my broken manual antenna with little luck. I managed to
disconnect it from my stock am-fm Blaupunkt, but am struggling with taking it off the fender. There is something holding it back(like a long straight piece?) Is there a procedure for screwing it off? Or do I have to go in under the fender? Does the new one have to have an adapter for the Euro radio?
Also on the topic..is there a site where i can find a manual for this radio?
Many thanks!
Ted.
I love to learn.. I dont always like being taught.
tedg is offline
post #2 of 5 (permalink) Old 07-17-2012, 10:10 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
Speaking from my '73 experience - you have to go under the fender. There is an access panel you remove and the antenna will come right out. You can replace it with another manual, electric or a generic one. There's loads of room there.
I do suggest you tie a string to the antenna wire before you pull it out; that will help you pull the new one in - assuming you don't reuse the old wire (as I recall you can unscrew it from the antenna).
As for the connector if you get a stock replacement it will have the same end but if you buy a different one you can get whatever you want.
Good luck
Frank
Frank Flynn. Poet, Artist & Mystic
Frank Flynn
'73 220D
'88 300SEL
'91 300TE
frankflynn is offline
post #3 of 5 (permalink) Old 07-18-2012, 09:30 AM Thread Starter
tedg's Avatar
Thumbs up
Hi Frank,
Many thanks for your informative reply. I took another look under the fender wheel well and did notice 3 screws that I can unscrew from a black panel.
I will let you know how it turns out...cheers...Ted.
tedg is offline
post #4 of 5 (permalink) Old 07-18-2012, 10:30 AM
frankflynn's Avatar
Vehicle: 1973 220D
Quoted: 2 Post(s)
Remember to get some goop (whatever it is) to seal the access panel when you put it back after 40 years the old stuff might not be as good. This is the gooey stuff - stays gooey forever any auto parts store will have some. Silicon calk and the like might work but some of them they get hard and can crack over time - also they can make it hard to remove the panel next time. Go for gooey.
post #5 of 5 (permalink) Old 07-21-2012, 07:36 AM Thread Starter
tedg's Avatar
It worked...
Thanks Frank it worked out great. I got the panel off with little effort and the antenna was so easy to remove..the new one fit great and now the ancient blaupunkt radio sounds great..now I have to look around for the goop to seal it up...many thanks...ted
Whitby, onTARIO Canada.
tedg is offline
