220D primary pump leak - pic fixable? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-10-2012, 04:16 PM Thread Starter
Date registered: Aug 2011
Vehicle: MB 220D/8
Hi
I am pretty sure I have located the source of the leak on the primary pump on the 1971 220D - it is coming from the base part of the left hand side fitting - I removed the banjo fitting and compression washers and when I use my thumb to push down on the top opening to cause pressure it is weeping out the bottom - can this part be removed? I have tried to move it but it does not want to shift - if so can that part be purchased or, can I use some kind of thread sealant on it?
Thank you
Lee
Britcheflee is offline
