1973 450SL Engine Harness Parts - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-10-2012, 06:55 AM Thread Starter
Date registered: Jul 2012
Vehicle: 1973 450SL
I have an early production 73 450SL. I'd like information on where I can buy engine compartment wiring harness components, specifically the connectors that plug into the sensors, trigger contacts, injectors, pretty much everything under the hood. I would even consider buying a complete engine harness if the price was reasonable.
Age and heat have taken their toll on everything under the hood. The plastic insulators covering the spade connectors are all brittle and broken, and even the insulation on the wire itself is brittle. I can rewire it myself IF I can find the replacement parts. I just haven't had any luck finding them.
kgwhitehead is offline
post #2 of 4 (permalink) Old 07-10-2012, 07:02 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Proceed to the R107 forum.
flyboyike is offline
post #3 of 4 (permalink) Old 07-11-2012, 09:45 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
I had the same issue and ended up building my own replacement wiring harness, using old connectors. I also went to a junk yard and got a bunch of extras.
You *might* find replacement plastic bits (what the wires plug into) from an electrical store, but I had no luck. Hense, my use of old connectors.
I went to Radio Shack and bought a bunch of inner connectors - the things that the wires actually attach to. They're very common, and are held in the plastic with tiny barbs. Radio Shack sells the tool you use to crimp that in and replace the entire wire.
All you need is a soldering iron and shrink wrap, assuming your old rubber connector covers are shot.
I also bought a label maker, so I could keep track of what wires went to what. If you luck out and find a source for the exact wire-and-stripe match, let me know - I'd send them my business. Otherwise, you can make it work with a spool of wire from Home Depot and your Radio Shack connector kit.
Something I'd recommend is going to a junk yard and getting a used harness as a static display. Take it out of the car and in your garage, use it as a guide for length, etc.
And as much as it hurts my feelings so suggest it, you also might try the dealership or classic center, to see if they have such a harness in stock.
Grubeguy is offline
post #4 of 4 (permalink) Old 07-11-2012, 08:27 PM
Date registered: Aug 2010
Vehicle: 73 300SEL 4.5
Post
Junkyard is your best supply to get parts.
Also look other cars
I took the rubber boots of a 92-94 Volvo injectors to replace the ones on the
d-jet injectors, its tight but it fits and its functional. ( just the rubber booth not the connector)
this may help also
D-Jetronic-style Injector Connector - Marren Fuel Injection - Marren Fuel Injection
good luck.
thusa is offline
