Voltage Regulator - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-09-2012, 05:18 PM Thread Starter
Date registered: Mar 2012
Vehicle: 1972 Mercedes Benz 280SE
Voltage Regulator
I'm replacing the alternator on my 72 280se and I need to know where the voltage regulator is located. Any help would be appreciated. And a picture would be even better.
Thanks
prpalmer is offline
post #2 of 3 (permalink) Old 07-09-2012, 07:21 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
It's part of the alternator. When you buy a new one, it comes as a packaged deal.
Grubeguy is offline
post #3 of 3 (permalink) Old 07-19-2012, 11:52 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
I did not think they were part of the alternator until a few years later. On my '73 w115 they are separate. But it's easy to tell - the voltage regulator (if it is separate) is on the right fender, it is a small metal box and has a 3 wire connector on the bottom with rectangular pins on it. While the alternator has a connector with 3 round pins on it. The combined alternator / voltage regulator has the 3 rectangular pins on it.
On the combined unit the voltage regulator and the brushes are one small unit. If it is failing 80% of the time all it needs is the new brushes / voltage regulator unit (you don't even remove the alternator to replace it).
Good Luck,
Frank
frankflynn is offline
