w115 4 speed in a w111 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-26-2012, 11:58 PM Thread Starter
rwd4evr's Avatar
Date registered: Mar 2010
Vehicle: '85 300tdt (sold),'64 220b,'63 220Sb ,85 monte carlo ss 406SBC(4 sale),1976 vega wagon(sold)
Quoted: 16 Post(s)
i have a 64 220b with a 4 on the column. it got some pretty worrysome vibrations when the rpms get higher than maybe 4500 rpm or so,maybe 65 mph. no tach. the second gear syncros seem to be getting a bit cranky too. i am over the column shift st this point and found a four speed out of a w115 car i'm picking up(hopefully). any body done this or can think of the major issues involved?
rwd4evr is offline
post #2 of 3 (permalink) Old 06-27-2012, 07:50 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
Is your intent to swap transmissions, using your original car?
Grubeguy is offline
post #3 of 3 (permalink) Old 07-01-2012, 10:35 AM
trazique's Avatar
Date registered: May 2008
Vehicle: '99 CLK430, 62 220se, 64 220se, 65 220se, 66250se, 85 380sl, 90 190E 2.6
Quoted: 57 Post(s)
Send a message via Skype™ to trazique
You unlucky bastard, If I was in the country I could have sold you a floor shifting 4 speed that came out of aW111. I believe I have 2 left.
Anyways, just check to make sure the hydraulic setup is the same along with the bell crank housing bolt pattern (which should be no problem). Other than that should be a breeze.
trazique is offline
