What to replace for AC for '74 240d - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-17-2012, 09:38 AM Thread Starter
Date registered: May 2012
Have a '74 240d, and original AC was disengaged by previous owner because even when when you turned off the AC, the compressor would constantly run and blow hot air into the car. Rather than fixing it (it was winter), he just disengaged it.
Since the compressor and dryer are original, I have decided to replace those units ( a local MB mechanic will be doing this because I don't think I have the expertise yet). So here are my questions:
1. The AC compressor is a York R210R-2013, and when I looked around the Internet I found many that are rebuilt around $300 (Four Season brand), and new are $700. This is my daily driver and not restoration project, so go with the rebuild? What are your thoughts on rebuilt parts vs. brand new?
2. Since, I'm replacing the main AC components, I wanted to see if there was anything else I should replace other than the Compressor and dryer?
3. To save costs, I'm buying the parts and mechanic will put it. He told me to also purchase a dryer switch. However, when I look online for the dryer switch, I really don't see a specific switch. Many part sites always just point to the dryer/blower unit, which I'm already buying. What is the dryer switch and what is the part number?
4. When I look online for the compressor, they ask if it has a clutch or no clutch. My car is in the shop, so can't look at it, so how do I know if a '74 240D has the clutch or clutchless compressor?
ifthecar is offline
post #2 of 3 (permalink) Old 06-18-2012, 07:49 AM
Replace all hoses they are old and will leak next when pressure is applied.
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 06-19-2012, 05:42 PM
r34sklnnsn's Avatar
Date registered: Feb 2012
Vehicle: 1971 250C
The clutch is the part that the belt turns, it engages then you turn the AC on. If your clutch will disengage then the clutch is probably fine. That being said if you are replacing the whole compressor unit I would opt for one with a new clutch to be on the safe side
'71 250C "work in progress"
r34sklnnsn is offline
