1976 300D signal switch - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-16-2012, 04:37 AM Thread Starter
Date registered: Jun 2012
Just bought a 1976 300D, currently heading west in it. The signal switch works but, you have to hold it down or up, it does not lock into position so your hands free like normal shifts. Will hit a spot to do some work on it today, might me a minor thing. Any suggestions?
Cheers
maxcruise is offline
post #2 of 3 (permalink) Old 06-16-2012, 09:52 PM
toofles's Avatar
Date registered: Apr 2004
Vehicle: 83 300sd 76 240d
signal switch
mercedessource.com is a parts website, and they also have a tech help section.
they have a large section of troubleshooting and repair videos you can watch for free.
the early mercedes turn signal assembly repair is listed in the interior repair category.
hope it helps, good luck with it
toofles is offline
post #3 of 3 (permalink) Old 06-23-2012, 09:05 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
The switch itself is easy to replace - 10 minute job really. But since it is a combination (turn signal, wipers, high beam) they are expensive.
You can file down the little latch that holds the switch in place and it will work much like new until it wears out again. You can only do this once or twice and then you have to replace it.
Good luck
frankflynn is offline
