220D vacuum pump repair - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 06-13-2012, 01:24 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
You can clean the pipes with a piece of rag and brake cleaner, but the function of the vacuum pump will not be impaired if you don't.
I would change the valves too even if they appear to be ok, but I am of the opinion that a repair should last, but you can always try, maybe the valves will last for a long time after you have replaced the diaphragm.
Don't forget the torque: 9 Nm for the diaphragm screw, 5 Nm for the main cover screws and 2.5 Nm for the valve cover screws. That is all very light.
Govert70227 is offline
post #12 of 16 (permalink) Old 08-05-2012, 11:38 PM
Date registered: Jan 2011
Vehicle: UNIMOG 421.129 HardTop
Hi,
Nice illustration, could you please tell what is the purpose of external cap with two screws or it possible to install diesel lift on the external cap.
Regards,
Abdul.
abdulr76 is offline
post #13 of 16 (permalink) Old 08-05-2012, 11:44 PM
Quoted: 4 Post(s)
Under the external cap with the two screws are the two valves.
You cannot use that as a diesel lift pump (and why should you want to?).
post #14 of 16 (permalink) Old 08-06-2012, 12:17 AM
Hi Govert70227,
Bundle of thanks for reply, let me share my story with you.
I have Unimog 421 with Om616.912 engine. The Unimog is without brake booster and I want to install brake booster for which I need a vacuum port or pump. MB 240D comes with vacuum pump but in Unimogs hour meter with Diesel lift pump is installed. So, by replacing hour meter with vacuum pump (simple bolt-on) I can get vacuum for Brake Booster but I am unable to install diesel lift pump on it (you just confirmed). Engine room is very congested and I can not install Diesel Lift pump on IP as well. That why Diesel lift pump is installed on Hour Meter.
Option 1. Install 240D vacuum port and install a electric fuel pump for feed IP.
Option 2. Forget about 240 vacuum pump and replace Alternator with vacuum port. It requires one oil deliver and return line to the engine. I thinking to get delivery line from Oil pressure switch (by install a T) and return line to valve cover or oil sump.
Option 3. Install external vacuum pump (belt driven) with some modification in engine room and use same option 2 oil delivery method.
OR if some provide me brilliant idea on the Forum.
Look forward to good resolution...................
Regards,
Abdul.
abdulr76 is offline
post #15 of 16 (permalink) Old 08-06-2012, 02:40 AM
Quoted: 4 Post(s)
And you cannot install a lift pump on the IP? that is the normal place for the lift pump.
Otherwise an electric lift pump would be the easiest solution in my opinion.
post #16 of 16 (permalink) Old 08-06-2012, 03:05 AM
Thanks for reply, more opinions are welcome.
abdulr76 is offline
