My 1978 300CD gear shifter will not shift gears and is stuck in drive - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-28-2012, 10:15 AM Thread Starter
Date registered: Mar 2012
Vehicle: 1978 300 CD
I have had this car a month, and the gear shifter was loose when i purchased it. The car started shifting out of park and rolling this morning when i parked it. I am out of town, and was returning home when this happened. I was pulling out of a gas station, and the reverse would not engage., It is stuck in what i believe is low, and i wanted to see if there were any bandaids that i can use until i get home. My guess is there are some plastic bushings that keep the shifter in place??
craig78676 is offline
post #2 of 2 (permalink) Old 05-28-2012, 01:23 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Under the car is a rod, it runs from the shifter to the lever on the transmission. The rod has a plastic bushing at both ends.
Govert70227 is offline
Transmission doesn't shift gears - 1st gear working only and Reverse mercedesc230 W202 C-Class 4 03-01-2012 03:39 PM
Gear shifter stuck in drive JimmyD0119 R170 SLK-Class 14 08-30-2011 12:17 PM
260E Shifter stuck in Drive and Neutral! Any Help?? chlippo W124 E,CE,D,TD Class 3 12-22-2009 09:57 AM
**URGENT** Shifter Stuck in Drive!!! BlkAce W202 C-Class 6 10-10-2009 03:46 PM
Transmission issue: No forward drive gears in 78 300CD gavin_leslie W123 E,CE,D,CD,TD,TE Class 9 11-14-2007 11:32 AM
