w108 driver's seat alignment - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-26-2012, 06:13 AM Thread Starter
Date registered: Mar 2011
While doing some work with the driver's door open on a recently acquired 1973 280SE 4.5, I noticed that the driver's seat seemed out of alignment, canted at a shallow angle to the left. I sat in it and squared my body into the seat, and could tell that I was facing slightly to the left rather than directly ahead. Measuring against the front edge of the floor platform on which the seat is mounted, and from the straightest part of the piping on the back seat to the back of the front seat, confirmed that the orientation was about a half-inch off over 12 or so inches -- equivalent to a 3 to 5 degree angle.
I wondered why I had been fidgeting and unable to get into a comfortable driving position, and this may be it.
Does anyone know of a likely cause, adjustment or fix for this problem?
ross220sb is offline
post #2 of 5 (permalink) Old 05-28-2012, 10:32 AM
You must remove the seat and adjust the rod between the sides and rebuild the seat pads. clean the tracks too.
The assembly trick is to put the track spring on last.
Brian O
bostosh is offline
post #3 of 5 (permalink) Old 06-02-2012, 07:27 AM Thread Starter
Thank you -- this give me good guidance. I may have to have the work done rather than do it myself, but at least I know there's a solution.
post #4 of 5 (permalink) Old 07-13-2013, 05:39 AM Thread Starter
For what it's worth, I discovered the cause of this problem. Recently when I had the seat out for some upholstery work, I discovered a flattened penny wedged in the up/down track, causing one side to drag or stick when the seat position was changed!
post #5 of 5 (permalink) Old 07-13-2013, 08:30 AM
Date registered: Aug 2009
Quoted: 49 Post(s)
That makes "cents" of why you had the adjustment problem.
Mike D is online now
    w108 seat belt kdjones99 Vintage Mercedes-Benz 4 09-28-2011 07:11 AM
    Wiper alignment driver's side waderamsey W220 S-Class 0 09-19-2010 06:50 AM
    W108 - Wheel Alignment Specs jp_280s Vintage Mercedes-Benz 3 12-31-2008 07:14 AM
    Seat belt/buckle problem: 91 420sel driver's seat neevy W126 S,SE,SEC,SEL,SD,SDL Class 11 11-04-2007 09:08 PM
    Why is removing the driver's seat not like the passenger seat? Halfwise W123 E,CE,D,CD,TD,TE Class 12 10-22-2007 08:48 PM
