Battery issue?? Starter?? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-25-2012, 12:30 PM Thread Starter
BlueSkiesWhiteClouds's Avatar
Date registered: May 2011
Hello BW members,
I am having an issue with my 280 and it's inabilty to keep a charge and start every morning..I charged up my battery for hours.. The car starts right up. Overnight it seems to lose it's charge or perhaps the battery is just shot?!! I don't really think it is my starter because as soon as I pull out my portable jumper, it fires right up immediately...
Usually after it has run for a few it will fire right back up but today it doesn't fire back up, it requires me to get out my jumper and again immediately fires right up.. Any ideas before I go into a shop? Thanks all and Happy Memorial..
BlueSkiesWhiteClouds is offline
post #2 of 8 (permalink) Old 05-25-2012, 07:59 PM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
It's not the starter, I'd replace the battery and see if that fixes your problem.
With the hot weather many batteries are failing, it's extremely common to see a ton of posts about failing batteries in the beginning of summer.
(and just jump starting the car is putting a lot of strain on the alternator's voltage regulator, I'd recommend replacing the battery before you cook your voltage reg.)
tgikal is offline
post #3 of 8 (permalink) Old 05-25-2012, 09:58 PM Thread Starter
Thanks...just charged the battery and it fired right up..I guess we'll find out in the morning....I will probably go out and purchase a new battery just for good measure considering i've left the lights on 4 or 5 times causing DEAD BATTERY...
post #4 of 8 (permalink) Old 05-25-2012, 11:09 PM
Date registered: Jun 2009
Battery's probably dead. Better have your electricals checked also in case you have a grounded wire somewhere causing the overnight drain.
ijiwaru is offline
post #5 of 8 (permalink) Old 04-29-2014, 09:15 AM
I went through 2 batteries on my 280C, each lasting only a year. The problem was a short. Also be sure your positive cable is bolted to the positive post. It will start (for a while) if connected wrong. Someone previous had put in a new cable and they were both marked positive.
280c75 is offline
post #6 of 8 (permalink) Old 04-29-2014, 06:08 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
If by this, do you mean the cables reversed - negative (ground) wire to the positive battery post, and the main cable to the negative battery post? The car won't start at all - it'll most likely destroy the wiring harness after a good electrical fire starts.
Grubeguy is offline
post #7 of 8 (permalink) Old 04-30-2014, 06:51 AM
Sorry to differ, but, yes, it does start. There was another post back awhile which agreed that it will start. Do you own a 1975 or older?
280c75 is offline
post #8 of 8 (permalink) Old 04-30-2014, 08:16 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
i you want to see if it is the battery , disconnect it the night before , and reconnected in the morning , if car starts fine , it is not the battery .it is critical that you say what year the car is , 76 on has a problem with the climate control that will drain your battery over nite .
agillot is offline
    Massive headache: Starter Motor / Battery / Alternator issue Qualm W124 E,CE,D,TD Class 11 09-14-2011 02:29 AM
    Starter issue? Vector_03 C215 CL-Class 7 11-15-2010 08:26 PM
    80' 240D either alternator or starter issue, battery dies quickly. Gvigorus W123 E,CE,D,CD,TD,TE Class 14 10-08-2007 08:44 AM
    Starter issue kef W123 E,CE,D,CD,TD,TE Class 2 07-08-2007 06:32 PM
    Alternator/Starter/Battery cable issue Gvigorus W123 E,CE,D,CD,TD,TE Class 26 11-10-2005 01:21 AM
