Engine starts and immediately stops - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-22-2012, 10:32 AM Thread Starter
Date registered: May 2012
My neighbor has a 1973 450 SEL. It stopped running and he had it towed in. The engine will immediately fire off and immediately die. We have checked the fuel pressure, timing, and the power from the coil. It has electronic controlled fuel injection, not mechanical. We are not familiar with this system and need more info and direction than the Haynes manual can give. Any replies to a possible solution are welcome. This car is extremely fun to drive and 80% restored; so we want to get it up and running again!
jmyshry is offline
post #2 of 2 (permalink) Old 05-22-2012, 10:56 AM
Date registered: Apr 2007
Vehicle: 1999 E320, 1975 450SEL, 1979 280SE
Quoted: 8 Post(s)
Scroll down to the W116 forum and check out the diagnostics in the stickys on the Jetronic fuel injection systems. This should help!
rabbit188 is offline
    1997 E420 AUXILLARY FAN STARTS RUNNING IMMEDIATELY IGNITION IS TURNED ON garvin1 W210 E-Class 5 03-26-2011 07:55 AM
    '07 C280 starts and dies immediately pcy W203 C-Class 4 07-12-2010 09:41 AM
    2.3 Starts but then stalls immediately don_xvi W201 190-Class 4 03-07-2010 10:51 AM
    My 2004 C240 engine starts and then stops bysybee3 W203 C-Class 1 12-28-2009 08:36 AM
    ML Starts/Stops with Check Engine/Battery Light Benzlova W163 M-Class 4 07-26-2009 12:32 PM
