280SE 4.5 Wheel Bearing - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-21-2012, 11:20 PM Thread Starter
Date registered: Feb 2012
Hey, I bought a w108 and I am pretty sure the drivers side rear wheel bearing is shot. Makes a whirring sound and when turning right, the weight of the car shifts and makes it louder. Now my question is how similar is the 108 chassis to the 113? I found a guide on how do to a rear wheel bearing on a w113 but couldn't find 108 specific info.
If anyone has words of wisdom on this issue please tell me!
Thanks
w108martin is offline
post #2 of 2 (permalink) Old 05-22-2012, 09:05 AM
rear noises
Jack up the rear tire by a bottle jack under the aft area of trailing arm about 1/2Inch..
Then run the car (use an assistant) and listen at the rear.
I have run thru all gears up to 60-70mph
It could be the wheel bearing
the u-joint inside the axle.
Stop the car and shake the rear wheel to determine id it is the u-joint.
Brian O
bostosh is offline
    Front wheel loose/Wheel bearing Adjustment E-Fam W210 E-Class 9 04-22-2010 06:00 PM
    NEED HELP ! Wheel bearing and center support bearing for 420SEL rapcat W126 S,SE,SEC,SEL,SD,SDL Class 32 11-17-2008 11:54 AM
    wheel bearing? chong188 W202 C-Class 8 11-03-2008 07:32 PM
    NEED HELP ! Wheel bearing and center support bearing for 420SEL rapcat For Sale/Wanted/Trade/Giveaway 0 10-01-2008 05:40 PM
    Rear Wheel Noise... Parking Brake or Wheel Bearing? AFARR W201 190-Class 2 05-07-2005 03:28 PM
