Sticking caliper - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-21-2012, 10:04 AM Thread Starter
Date registered: Aug 2011
Vehicle: MB 220D/8
Sticking caliper
The rear caliper pistons appear to be siezed after having sat for many years - this is father in laws 71/72 220D - managed to get the pads out and now trying to free them up any tips to get this done without having to remove the calipers?
Lee
Britcheflee is offline
post #2 of 3 (permalink) Old 05-21-2012, 09:52 PM
Pull them and rebuild them or they will forever squeal and/or not work properly, do the hoses too. front and rear.
check and adjust the parking brake while you are in there.
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 05-21-2012, 10:09 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
If they are that bad you may not be able to salvage them. They're probably corroded and pitted inside, unfortunately.
Good luck.
Check Codes is offline
Drivers side brake caliper pistons stuck out (only on one side of the caliper) tkv000 Unimog 53 04-23-2014 11:49 PM
Sticking brake caliper? Deserion W124 E,CE,D,TD Class 4 05-03-2012 08:28 AM
e200 Caliper sticking e300estate W210 E-Class 7 08-16-2010 04:58 AM
Top Sticking when it's hot joshelley R170 SLK-Class 9 08-01-2006 11:23 PM
sticking in 1st... catboy W124 E,CE,D,TD Class 2 09-03-2004 02:12 AM
