Newbie to MBZ needs help on 450sl 73 please! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-17-2012, 12:25 PM Thread Starter
Date registered: Jan 2010
Vehicle: 1981 300 TD
Thanks to all for help. First MBZ from having 8 BMW's. Always loved this model. It will fire and run if I am pouring gas into carb, but won't start on it's own. As long as gas is being poured in, it will run and run great!
1. Any thoughts? These don't have ECU's correct? Plugs getting spark.
Appreciate it again and thanks in advance for being kind to a newbie!
Shebuilt is offline
post #2 of 4 (permalink) Old 05-17-2012, 10:58 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Try the R107 subforum here under Roadsters in the drop down menu, that's the car you have. Probably better quality of answers.
Out of curiosity, do you not count the 560sec in your sig as a "First Benz?" Seems legit to me!
The Coupe Group on Facebook
DirectLA is offline
post #3 of 4 (permalink) Old 05-17-2012, 11:49 PM
joeSEC's Avatar
Date registered: Jan 2008
Vehicle: 1983 500 SEC Lorinser 1971 280se w108
Check the fuel pump relay and the fuel pump
joeSEC is offline
post #4 of 4 (permalink) Old 05-18-2012, 06:07 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1569 Post(s)
A 73 450sl is an r107, and the correct forum for that car is here: R/C107 SL/SLC Class - - Mercedes-Benz Discussion Forum Perhaps a moderator could move this thread over there, or you could start a new thread.
Good job at least narrowing down whether your problem is with spark, air, or fuel.
There is no carb on a a 73 450sl (or any 450sl). The 72-75 are D-Jetronic Bosch fuel injection. There are a few things it could be, but the most common is the fuel pump not running, which could be the fuel pump itself, or the fuel pump relay (often abbreviated FPR since it is such a common problem on all 107s, D-Jet or not).
The good thing about the fuel pump relay on the D-jet 107s is that all the relays are the same, and you can simply swap out the FPR with another relay, and usually see if that is your problem without spending a penny.
The bad thing is that you will have to:
- remove the fuse panel cover in the passenger footwell
- remove the chrome strip at the front of the door jamb.
- remove the cardboard side panel
- remove at least one screw to get the metal bracket out of the way
- pull out the FPR, which I think is the top front (or left as you are looking at it) relay, and put another in its place.
The w107 group is incredibly helpful, and taught me everything I know. The FPR was a problem I had early on in my 73 450sl ownership. It is quite common, and the forum quickly helped me out. The forum has an "encyclopedia" for all of the tips and trick to owning these cars, and you definitely should read it, or at least understand the information that is there if you are even considering 107 ownership.
- That should lead you to here:
I hope to see you in the 107 forum.
Good Luck!
Fonzi is offline
    Newbie with a 75 450SL hollywood8118 Vintage Mercedes-Benz 7 08-27-2009 06:37 PM
    Newbie with a 450sl that won't start - help? atp R/C107 SL/SLC Class 5 04-16-2009 06:20 AM
    1979 450sl newbie here erpope General Mercedes-Benz 0 08-06-2008 03:49 PM
    NEWBIE BUYING 450SL funinthesun R/C107 SL/SLC Class 1 06-21-2007 01:14 PM
    77 450SL newbie minus1 R/C107 SL/SLC Class 4 12-06-2004 10:12 PM
