wont turn over sometimes - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-13-2012, 10:16 PM Thread Starter
Date registered: May 2012
Vehicle: 78 euro 300d
78 euro spec 300d, In the morning I inset key in ignition turn to right , wait for glowplugs to turn off then send the key to the right, Nothing, turn all the way off and repeat maybe 3-4 times then finaly one time it starts. When it starts it starts right up. Do I need a new ignition? Why does nothing happen? I really dont want to be stranded one day. I am a new merc owner'
brian.mountain is offline
post #2 of 8 (permalink) Old 05-14-2012, 09:29 AM
are there service records? receipts for work done?
if no
then get a new battery, clean all cables from battery to starter and ground connections, remove and rebuild starter.
These are normal maintenance items and if neglected.......
These diesels are very dependent upon these items.
You do not want to get stranded by not having a perfect starter system.
Brian O
bostosh is offline
post #3 of 8 (permalink) Old 05-14-2012, 03:30 PM Thread Starter
Just replace battery? I dunno im not for switching out parts for no specific reason. when the starter works it works fine, no click no buzz no grind it works just fine. The battery seems just fine as well(i will bench test it today) but there is no reason for me to believe its the battery, when it works it works just fine, maybe there is a ground wire loose maybe its a way to tell me to replace the ignition switch? do these go out often? Ive had this thing for a week and its my first benz only has 120k miles on it. Im a decent mechanic but this is a new beast for me.
post #4 of 8 (permalink) Old 05-14-2012, 04:47 PM
With a good battery and at 120k miles the starter would be needing a freshening up,
Ive done this and the spin is optimized
The brushes get worn, the starter insides get crudy, rebuild.
the key switch could be the next and do fail more rarely.
Brian O
bostosh is offline
post #5 of 8 (permalink) Old 05-14-2012, 07:33 PM Thread Starter
Battery is good, I believe it may be the key switch, it just did it to me again. The starter will probably be my next overhaul(I do this in phases) but for now it seems there may be a short in the ignition switch. iF the starter gets its juice it works perfectly, turning the key doesnt seem to get it the juice
post #6 of 8 (permalink) Old 05-15-2012, 07:53 AM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
Your car should have a 3-wire terminal block on the right side inner fender near the firewall. You can test the ignition switch by shorting the center wire to the one toward the front of the car (I think it's a purple wire). Anyway, it's the one that runs down to the solenoid. If that doesn't' start the car, the starter is bad or you have a bad ground somewhere.
While shorted and the car still doesn't start, try whacking the starter with something. If it turns over then, the solenoid/starter is going out.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #7 of 8 (permalink) Old 05-16-2012, 03:49 PM Thread Starter
It happened again and I held the key in the start position and with my other hand moved the shifter a bit,(it fired right up) it must be the neutral safety switch a bit outa spec/wack! jees those are a bit pricey...
post #8 of 8 (permalink) Old 05-16-2012, 08:25 PM
Quoted: 36 Post(s)
In that case, it may just be the shifter bushings that are worn or missing.
Much cheaper to replace. Search around on the w123 forum for a lot of good info.
    Key wont turn, engine wont start moreyb22 W203 C-Class 6 12-27-2016 06:43 PM
    CD changer motor wont turn off, door wont open mhouston W211 E-Class 1 11-28-2014 07:28 PM
    CD changer motor wont turn off, door wont open mhouston Audio & Telematics Forum 0 12-03-2011 08:49 AM
    help please! my key wont turn in ignition barrel and wont start car!! cazzano1989 W203 C-Class 2 09-02-2010 08:27 PM
    doors / boot wont lock - key wont turn alberto28 W202 C-Class 0 05-16-2010 01:33 PM
