220D 71/72 Differential question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-09-2012, 09:54 AM Thread Starter
Date registered: Aug 2011
Vehicle: MB 220D/8
Me again - after getting the leak fixed on the car took it for a run - was ok until after about 10 miles when started getting random clonks and bonks from rear end - then when going around corners some creaking/squeeking noises - at first I thought it might be the differential but would imagine this would be a constant whining noise if there was a problem with it - any ideas? Worn bushings? Shocks worn? bearing?
Thank you
Lee
Britcheflee is offline
post #2 of 3 (permalink) Old 05-09-2012, 07:44 PM
Matvh's Avatar
Date registered: Jan 2011
Vehicle: 1969 280 SE Convertible
Inspect
The key to these older MBZ is to do research on the components and maintenance. This is achieved by reading tech manuals and researching forums.
Put the car on a lift. Inspect suspension, axles, seals, u-joints, etc.
Drain the rear axle oil, inspect the oil for debris?
Take pictures of the rear axle with proper inspection data and post on this forum.
We can help with the proper info.
Matvh is offline
post #3 of 3 (permalink) Old 05-10-2012, 04:53 AM
Date registered: Aug 2009
Quoted: 60 Post(s)
Check the stabilizer links on the rear. Pretty common for these to fail if the car isn't driven often. They are ball and socket ends and when they break they can make a heck of a racket. Easy fix.
Mike D is offline
    Another 220D question Britcheflee Vintage Mercedes-Benz 7 09-05-2011 12:44 PM
    Got a nice 72 220D, Whats a better differential ratio? rdraper Vintage Mercedes-Benz 7 04-17-2011 11:43 PM
    1973 W115/220D Performance Question VersysRyder Vintage Mercedes-Benz 0 05-18-2009 05:57 PM
    Question on W115 220D tointexas Vintage Mercedes-Benz 2 01-11-2006 08:20 AM
    69 220D Vaccum pump question dumont Vintage Mercedes-Benz 2 10-12-2004 01:08 PM
