450 SEL front axle question - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-07-2012, 09:01 AM Thread Starter
Date registered: May 2012
I purchased a 73 450 SEL that had been sitting for 10 years with a fuel pump leak. It has 82K on it and I fixed the fuel system and it runs now. But it had a large clunking sound in the front end which turned out to be the bearings failing on the driver's side. After a new axle, all seems well, but I have some doubts. I have not driven it more than a few miles because of this.
The haynes manual shows a diagram that includes a thrust washer, but my car W116 chassis did not have thrust washers on either side, only the special nuts. Should it have thrust washers and if it does need them where can I get them?
Bill
ranchodenieve is offline
    Replacing 4matic front axle question garrettt3 W124 E,CE,D,TD Class 12 01-20-2016 08:54 AM
    4matic front axle cleaning question msteelsos W124 E,CE,D,TD Class 2 04-08-2012 05:01 PM
    Replacing 4matic front axle question garrettt3 W123 E,CE,D,CD,TD,TE Class 1 10-28-2011 04:29 PM
    Right Front Axle Shaft Disconnected from Front Axle Gear chiman0101 W164 M-Class 2 05-10-2011 05:48 AM
    Front Axle Question - E320 4matic rondo W210 E-Class 7 11-26-2006 12:35 PM
