1971 280se 2.8L Points Gap? New Points, Not Starting. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-27-2012, 09:20 PM Thread Starter
Date registered: Aug 2010
Vehicle: 1971 280SE
Car was running a little rough. Points looked ancient so i changed them along with cap, rotor, condenser. Now, i cannot get it to run. The condenser they gave me was a little larger and had the wrong connector on it. i spliced in the old one. Points are getting 12 volts with key on. I set the points at the highest point on the distributor shaft. Set points at 13, then 15, then 17 then 25 with a feeler gauge and still nothing. What should they be gapped at? Any ideas?
Blue shark is offline
post #2 of 3 (permalink) Old 04-28-2012, 05:58 AM Thread Starter
Vehicle: 1971 280SE
anyone?
post #3 of 3 (permalink) Old 04-28-2012, 06:13 AM
ktmripper's Avatar
Date registered: Jun 2010
I've got a haynes manual that describes this in chapter 4. you can borrow it today if you want. Give me a call, I'll bring it by.
ktmripper is offline
Buy Points DP Off-Topic 20 08-16-2011 08:31 PM
What are the known week points in C-280 or C-230? paradox96 W202 C-Class 1 02-26-2008 07:20 PM
Weak points? janos_z W203 C-Class 10 11-26-2007 10:49 PM
Jack up points ?!? Benz Stiller R170 SLK-Class 2 04-10-2007 03:02 PM
Triggering points. Guest R/C107 SL/SLC Class 2 03-17-2006 01:56 PM
