Glow Plug Issue Mercedes 240d 1974 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-24-2012, 05:48 PM Thread Starter
Date registered: Apr 2012
I replaced the glow plugs on my 240d as it was not starting. New plugs are in, everything is connected, but it seems that only the first plug is working. All 4 plugs test well.
My glow plugs use the old fashioned metal wire to connect from plug to plug. Is it possible that wire is no longer carrying a charge to the other plugs?
Please help.
jh2020 is offline
post #2 of 4 (permalink) Old 04-24-2012, 05:49 PM Thread Starter
When I pull the manual switch the salt shaker display heats up VERY quickly within ten seconds. It seems like only the first plug is working but I know all 4 are good.
jh2020 is offline
post #3 of 4 (permalink) Old 04-25-2012, 04:41 AM
Date registered: Aug 2009
Quoted: 66 Post(s)
By "first plug" are you referring to cylinder #1 or the first plug in the power circuit (actually cylinder #4)? If you mean #4 then check the wire loop between #3 and #4. It is easy to have this wire upside down which will make contact to ground completing the circuit on only the #4 glow plug. It only grounds when the accelerator linkage is pressed down so it's easy to install incorrectly since you don't notice it with the linkage at rest.
Mike D is offline
post #4 of 4 (permalink) Old 04-25-2012, 10:21 PM Thread Starter
Problem solved for the moment. I put in a new glow plug system that fires each one independently instead of in sequence. It starts with two and I will get two more tomorrow.
jh2020 is offline
    Help with Duraterm glow plug update 1974 240D 1974benzman Vintage Mercedes-Benz 2 03-11-2011 04:23 AM
    Where can I get Glow Plug bushings for a 240d? rathersmart W123 E,CE,D,CD,TD,TE Class 20 03-02-2011 09:01 AM
    1974 206D Glow Plug Questions studebakerman2001 Vintage Mercedes-Benz 0 04-06-2010 10:45 AM
    1974 240D glow plugs onefew Vintage Mercedes-Benz 4 01-20-2010 08:09 AM
    78 240d Glow Plug Problem madeintaiwan W123 E,CE,D,CD,TD,TE Class 7 09-23-2006 03:50 PM
