'65 W110 - Column shifter bushing replacement question - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-21-2012, 11:21 AM Thread Starter
Date registered: Apr 2012
'65 W110 190C, had no trouble replacing the upper bushings near the steering column. However, the bushings at the firewall that hold the shift rod are completely shot - how do you get it apart? Been trying to figure it out for an hour now, no dice! Any tips much appreciated!
ar design is offline
post #2 of 2 (permalink) Old 04-21-2012, 05:59 PM
wbain's Avatar
Date registered: Dec 2003
Be aware this job is difficult due to alignment of the shift rods and the levers that operate them.
There are four nuts at the base, on the inside, that need to be undone. The little shift 'transmission' can then be removed on the engine side. Use a helper. Put the shifter in neutral and forward towards the dash. There is a little cover that has to some off the shifter 'transmission' and a nut that needs to be loosened so it can be removed and the bushings can then be replaced. Don't remove the little pawl under the little cover.
I would advise against removing the steering column base due to the rust that causes the long screws to bind in the clip on nuts. I still don' know how to replace the clip on nuts.
Replace the shift rod bushings at the front of the rod as well as the one on the transmission shift levers, on top of the trans.
wbain is offline
    Shifter Linkage Bushing Replacement on 560SL Alkraut R/C107 SL/SLC Class 19 02-22-2017 06:52 PM
    DIY Console Shifter Bushing Replacement 79Mercy W123 E,CE,D,CD,TD,TE Class 26 08-18-2016 09:10 PM
    PHOTO DIY- SHIFTER BUSHING REPLACEMENT G-AMG W210 E-Class 109 07-28-2016 07:17 PM
    Shifter Bushing Replacement yoffer W210 E-Class 4 08-20-2010 09:08 AM
    Shifter bushing replacement diy? the jury C208/A208 CLK-Class 0 11-28-2007 05:24 PM
