Water pump removal 250SE - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-21-2012, 12:07 PM Thread Starter
kdjones99's Avatar
Date registered: Jul 2010
Vehicle: 1967 250SE (W108)
Quoted: 4 Post(s)
Oh wise ones, any secrets for getting the water pump out?
I've got the fan off and bolts out of the pump, but it won't budge loose. Don't want to pry on it too hard as it's in an aluminum housing.
Thanks,
Klaus
kdjones99 is offline
post #2 of 3 (permalink) Old 04-21-2012, 06:07 PM
Matvh's Avatar
Date registered: Jan 2011
Vehicle: 1969 280 SE Convertible
Suggestion
Did you remove the radiator?
It would be a great time to take the radiator to a shop to have it cleaned and checked out for leaks?
This would enable you to have more room to remove the water pump.
There is a gasket between the water pump and the front housing.
I would suggest spraying the mounting flange with W D 40 and let it soak.
Grab the water pump and apply pressure.
If totally stuck, a little heat can budge it.
Patience, work it loose.
Matvh is offline
post #3 of 3 (permalink) Old 04-21-2012, 07:04 PM
wbain's Avatar
Date registered: Dec 2003
Knock the pump casting with a rubber mallet, it will come off.
wbain is offline
    power steering pump assembly swivel for water pump removal... soundquest W124 E,CE,D,TD Class 7 05-29-2012 07:22 PM
    Water Pump removal pushgod W124 E,CE,D,TD Class 31 11-08-2011 07:12 PM
    Need help Water Pump Removal jeff1733 W202 C-Class 2 03-02-2011 07:59 PM
    300 SEL 4.5 water pump removal unpolire Vintage Mercedes-Benz 6 12-20-2006 09:14 AM
    Water pump removal... ? jknight W201 190-Class 3 08-27-2005 01:38 PM
