Loose Ball Bearings in Sump - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 04-28-2012, 08:52 AM Thread Starter
Date registered: Jan 2011
Vehicle: 1969 220D
Originally Posted by Govert70227 View Post
And the alternator light on the dashboard must be working when you put the key in position II.
Hi Govert, Yes the light goes on when you turn the key and goes out when the car is started. Do you recall if a "hot wire" attaches to one of those B+ (battery positive post?) terminals?
Thanks, Greg
GHewgill is offline
post #12 of 12 (permalink) Old 04-28-2012, 11:48 AM Thread Starter
Vehicle: 1969 220D
Thanks, Greg
Whoops! Sorry to trouble you with the question. I discovered (and then remembered) what happened. When I took the alternator out and sent it back I used electrical tape to cover the hot wire to the rest of the bundle of wires so that it wouldn't short against the body of the car while I waited for the new alternator. It is now connected and running fine. Thanks again.
Greg
GHewgill is offline
Ball bearings in oil pickup? frenchfry W123 E,CE,D,CD,TD,TE Class 11 02-27-2012 08:18 PM
Ball joints and wheel bearings BigBossE320 W210 E-Class 3 10-25-2010 05:12 AM
ball bearings or ... gakz R170 SLK-Class 7 06-08-2008 09:47 AM
Ball bearings in the oil pan! Yikes! Fulcrum525 W126 S,SE,SEC,SEL,SD,SDL Class 3 05-29-2008 11:37 AM
Front seat ball bearings Bob J W124 E,CE,D,TD Class 3 02-22-2005 06:24 AM
