W108 csv - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-20-2012, 11:12 AM Thread Starter
jeanro_44107's Avatar
Date registered: Sep 2007
Vehicle: '85 190D; '66 250SE; '87 M6; '06 X3;01 E46
W108 csv
Hi guys,
Working on my cold start valve, I have noticed that having the solenoid taken apart from the csv, there is gasoline coming out when the ignition is in ON position( engine not running) I have tried to expand the spring that pushes the pin(in order to increase the pushing force) but without much improvement: gasoline is still coming out the hole and presumably is causing the engine to run rich. I am in the process to purchase a csv from a 280se posted by JustPassinTru, but I don't like to admit being defeated on a simple defect. Is there something I can do in order to stop the gas flowing thru the CSV when the engine is running? A stronger spring would do a better job? Where can I get a new one from?
Thank you, Jean
jeanro_44107 is offline
post #2 of 8 (permalink) Old 04-20-2012, 07:26 PM
Date registered: Mar 2012
Vehicle: 2 W123 300D's and 3 W124 wagons
I don't know if this is a clue or not, but on the one I pulled from the 280SE, I had to unbolt the solenoid from the base to get at one Allen bolt holding the base to the manifold; I notice with curiosity, that there is no gasket between the solenoid and the base. Should there be?
JustPassinThru is offline
post #3 of 8 (permalink) Old 04-20-2012, 07:33 PM
Also, since taking the pictures I sent you, I have cleaned off the solenoid enough to read its part number. It is Bosch 0 330 106 001. Only two of the base's three Allen bolts which attach it to the manifold had a washer, so my guess is, this is a service replacement.
Last edited by JustPassinThru; 04-23-2012 at 11:01 PM. Reason: Part number is 330 not 830. Definitely 001.
post #4 of 8 (permalink) Old 04-20-2012, 07:40 PM Thread Starter
There wasn't a gasket when I opened mine either, however when I managed to fix the electrical problem and have the solenoid finally activated, a lot of gasoline came out from between the valve and the solenoid base. Scouring a little for an O-ring, I have managed to find one that fit at the base of the solenoid and perfectly stopped the leakage. Now, I only have to deal with gasoline escaping from the valve into the manifold when the fuel pump is running. As I have mentioned probably, there is a spring inside the valve that seems to not push with enough force into the pin such way the gasoline cannot escape into the purging hole.
Thank you,
Jean
post #5 of 8 (permalink) Old 04-20-2012, 07:46 PM Thread Starter
Pictures
Originally Posted by JustPassinThru View Post
Also, since taking the pictures I sent you, I have cleaned off the solenoid enough to read its part number. It is Bosch 0 830 106 001. Only two of the base's three Allen bolts which attach it to the manifold had a washer, so my guess is, this is a service replacement.
Philip, I did get the P.M.s but not the pictures
post #6 of 8 (permalink) Old 04-20-2012, 10:29 PM
PM with pictures re-sent.
post #7 of 8 (permalink) Old 04-21-2012, 03:04 AM Thread Starter
I have them.Thank you
post #8 of 8 (permalink) Old 04-23-2012, 09:16 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
I have both the solenoid and the solenoid with assembly on ebay - check user srallen. there is a rubber o-ring that goes between the solenoid and the assembly and it is usually crappy and needs to be replaced.
Scoot is offline
    w108 xaliscomex Vintage Mercedes-Benz 6 12-09-2011 05:35 AM
    AGAIN, WTB W108 verdejor For Sale/Wanted/Trade/Giveaway 0 01-25-2011 12:14 PM
    LOOKING FOR A W108 verdejor For Sale/Wanted/Trade/Giveaway 0 01-18-2011 10:56 AM
    New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
    Looking for a W108 neemhakim Vintage Mercedes-Benz 3 08-11-2007 06:35 PM
