250SE coolant hose - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-19-2012, 03:15 PM Thread Starter
kdjones99's Avatar
Date registered: Jul 2010
Vehicle: 1967 250SE (W108)
Quoted: 4 Post(s)
250SE coolant hose
I'm getting ready to replace all of the coolant hoses. I need help finding this short hose below the thermostat that connects to a pipe running to the heater core. One end appears to be 18mm, the other maybe 22mm, Can't measure it until I take it off. In the attached pic, it's the short hose on the left (rear).
Thanks,
Klaus
kdjones99 is offline
post #2 of 5 (permalink) Old 04-19-2012, 06:47 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Can you measure the outside diameter of each side (of the metal part not the hose) with a caliper to be sure it's not a trick of the eye first? Then you can use off-the-shelf hose for such a small section.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #3 of 5 (permalink) Old 04-19-2012, 07:36 PM
Matvh's Avatar
Date registered: Jan 2011
Vehicle: 1969 280 SE Convertible
Check thermostat
Suggestion, change the thermostat while replacing the hoses.
How is the water pump? Inspect carefully from underneath looking for any signs of coolant leak.
I used Mercedes Benz hoses for the upper, lower and thermostat hoses.
I also used silicone heater hoses for the smaller 5/8 and 3/4 inch hoses.
Matvh is offline
post #4 of 5 (permalink) Old 04-20-2012, 03:13 AM Thread Starter
kdjones99's Avatar
Quoted: 4 Post(s)
The pump is starting to make noise so I was going to replace that. You're right, might as well do the thermostat while I'm at it.
I can't get my caliper in there to get an exact reading until I take the hose off. But it's 18mm going to the heater, the end by the block is around 22mm.
I guess I can try the dealer. Haven't had much luck with them. Not a lot of old mercs in the area, so they don't stock much,
post #5 of 5 (permalink) Old 04-20-2012, 04:53 AM
wbain's Avatar
Date registered: Dec 2003
It's a specially molded curved hose. They are available at the dealer and through the Classic Center.
wbain is offline
    Coolant plastic hose leak between black firewall(Heater Core Hose) omairtheman1 W220 S-Class 11 07-12-2015 12:51 AM
    1967 250SE Engine Coolant Drain Plug Location jwylie Vintage Mercedes-Benz 3 12-18-2011 11:54 AM
    cut coolant hose dbgrate W124 E,CE,D,TD Class 3 12-28-2010 06:19 PM
    Can anyone ID a coolant hose? HughF W201 190-Class 5 01-01-2007 08:50 AM
    Coolant Bypass Hose jrehm W123 E,CE,D,CD,TD,TE Class 7 10-11-2006 08:47 PM
