w111 trim - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-10-2012, 10:16 PM Thread Starter
Date registered: Feb 2008
Vehicle: 03 E320 Wagon 103k 04 SL500 74k 1971 280SE 3.5 Coupe 67Mustang 289 hipo conv,68 Firebird 400 conv
w111 trim
I have trim that is faded and my bumpers have very minor fading ........I have had good luck with blue-job paste on my bike ....is the trim all chrome on my w111? any recomendations for shining up the trim around the windshield , windows , rain gutters, bumpers ETC....
Thanks,
Tony
tulah is offline
post #2 of 5 (permalink) Old 04-10-2012, 10:43 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
I use #0000 steel wool for chrome that has very slight "pitting", it's not harsh enough to cause damage since chrome is very hard (the reason it's used), but I avoid it on the grille area, it seems more susceptible to fine scratches for some reason.
If you just got your car it is possible it has stainless steel bumpers and other bits since they are being manufactured for the aftermarket now and many people buy them to fix up a W111 on the cheap before reselling. Not particularly bad but SS does scratch much easier than chrome, tho it will never corrode, pit or peel.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #3 of 5 (permalink) Old 04-11-2012, 09:39 PM
Matvh's Avatar
Date registered: Jan 2011
Vehicle: 1969 280 SE Convertible
Blue Magic
I also use 0000 steel wool with Blue Magic Metal Polish
Work in small areas with good clean cotton rags.
Lots of work, but good results
Matvh is offline
post #4 of 5 (permalink) Old 04-12-2012, 08:30 AM
The trim around the lower area of windows can be stripped thru the anodize and the soft aluminum polished to beautiful.
Brian O
bostosh is offline
post #5 of 5 (permalink) Old 04-13-2012, 03:35 AM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
If you are asking about trim on your 280SE 3.5 coupe then the trim around the lower part of the windows will be chrome plated brass, not anodised Al. Real metal! You can tell by the weight, but if you want to check then carefully grind off a bit on the back side.
drew56cus is offline
    How Do You Replace Rear door Exterior trim Window trim ? harley03joe W220 S-Class 8 06-09-2012 02:12 PM
    Anybody want to swap Burlwood trim for my Zebrano trim? MafiaDON W140 S-Class 0 02-17-2011 05:50 PM
    W111 mechanical fuel injection cold start 1963 W111 220 SEB MercedesOtto Vintage Mercedes-Benz 1 07-29-2007 03:29 PM
    How can I change the stock trim to the wood trim? dvanlinge R171 SLK-Class 5 02-13-2005 08:03 AM
    C-Class 03 sport aluminum trim for laurel wood trim TILLMANN W203 C-Class 0 02-25-2003 11:14 AM
