67 250s Front Brake Calipers - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-07-2012, 08:33 PM Thread Starter
helleifenbein's Avatar
Date registered: Dec 2011
Vehicle: 1967 W108 250s
Quoted: 9 Post(s)
Question 67 250s Front Brake Calipers
Spent a little time trying to fit some calipers to the front today and no luck.
I picked up a set of re-manufactured cardone calipers, and when installed the disc rubs on the caliper. any body gone down this road. I have yet to speak with cardone. I thought about machining them to fit but it would be better if I could get a set that fit.I am using cardone part # 19-271 and 19-272. It is obvious I have picked up a different casting from what I pulled off the vehicle.
any advice would help as I gather momentum and parts for next weekend.
helleifenbein is offline
post #2 of 3 (permalink) Old 04-08-2012, 05:19 PM
ktmripper's Avatar
Date registered: Jun 2010
I got my calipers at O'riely's, I think around $60. They are rebuilt A.T.E.'s, no problems yet and they fit the rotors with no modifications. The nice thing about buying from a local parts store is that if you get the wrong part you don't have to ship it back.
ktmripper is offline
post #3 of 3 (permalink) Old 04-08-2012, 05:58 PM Thread Starter
Quoted: 9 Post(s)
After doing some research I have found that only one of the calipers does not fit. I think cardone used a bracket from a different ate part number. I will return it and hope they get it right. I picked them up at O'riely's. The guy at the counter was sure that I had the right part, we double checked the cardone part numbers, and with that. I started to think that someone had Frankensteined a brake system from a different model onto my front end. Luckily that's not the case and I should have the correct part by next weekend
Cardone re-manufactured caliper with wrong bracket.
Original Caliper
Subtle differences lead to a part that wont fit
Cheers
Dave
Last edited by helleifenbein; 04-08-2012 at 06:03 PM. Reason: pictures wont load/spelling
Are the front brake calipers from an 450SL interchangeable with 380SL Non-ABS Brake? joconab R/C107 SL/SLC Class 17 06-06-2012 06:11 PM
Mercedes 400E ATE Front Brake Calipers - Big brake upgrade for most W201 and W124 bsmuwk For Sale/Wanted/Trade/Giveaway 2 11-24-2009 11:03 PM
front brake calipers gravel W163 M-Class 2 09-10-2009 02:12 AM
Front Brake Calipers voodoo123uk V-Class 1 08-27-2009 05:30 PM
ATE front brake calipers mkrists The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 07-22-2005 01:41 AM
