Plug wires for 250SE - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-06-2012, 05:39 AM Thread Starter
kdjones99's Avatar
Date registered: Jul 2010
Vehicle: 1967 250SE (W108)
Quoted: 4 Post(s)
Just installed a pertronix and new plugs (NGK) using the stock coil. Noticed that the old plug wires would spark from the metal casing to the block if it gets pulled from the plug. I guess it's time to replace them.
What wires should I get for this setup?
kdjones99 is offline
post #2 of 2 (permalink) Old 04-06-2012, 08:18 AM
Use solid core wires if you can get 15ft length of it and unscrew and re-screw the ends,
If the wires themselves are "soft" sorta new
Pull the spark plug cap off, pull the wire out, clip 1/4" off, poke an ice pick into the wire to give the cap a start lube the wire (spit works) and re-screw the wire into the cap. I've done this hundreds of times.
or get new wire set Solid core only.
Clean the inside of the caps copper terminals and tip of the rotor
Brian O
bostosh is offline
    1967 250SE Engine Coolant Drain Plug Location jwylie Vintage Mercedes-Benz 3 12-18-2011 11:54 AM
    Spark Plug Wires: So, which plug wire goes where ? Pancho C208/A208 CLK-Class 2 11-24-2011 05:10 PM
    Need help with plug wires osprey170 W126 S,SE,SEC,SEL,SD,SDL Class 16 03-06-2009 08:55 PM
    Spark plug wires / Ignition Wires DETANE W163 M-Class 11 04-24-2007 05:29 AM
    Considering getting a set of these plug wires... Aspect W126 S,SE,SEC,SEL,SD,SDL Class 10 03-09-2007 04:50 PM
