76 280 Low oil pressure when idling - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 03-25-2012, 10:16 PM Thread Starter
BlueSkiesWhiteClouds's Avatar
Date registered: May 2011
Hello,
Can anyone shoot some advice my way on this most recent issue? About a month back my car started showing signs of Temp rising while sitting at lights or drive thru's. The gauge will go almost to the 3rd line (next line being HOT)... Once I accelerate, the temp goes back to normal..Immediately!!!
Now, while I am sitting at lights it seems like I am idling very rough, almost as if she wants to stall,,,but she hasn't ...YET. during this my oil gauge will read near 15 which is low...As soon as I accelerate or if I put the car in neutral, the gauge reads pretty much full pressure 45...
any ideas on what this could be? I was running low on oil and put a 5-30 weight oil..From what I have been reading, these cars need a 20-50 for this Cali weather..any suggestions are appreciated...
Thank you
BlueSkiesWhiteClouds is offline
post #2 of 8 (permalink) Old 03-26-2012, 06:48 AM
ktmripper's Avatar
Date registered: Jun 2010
Low idle speed and overheating, sounds like two different issues. Is your idle set fast enough. too slow of idle speed can cause stalling and low oil pressure. If not that, maybe tune up parts(plugs,cap,rotor ,wires,points etc). check for low coolant also.
ktmripper is offline
post #3 of 8 (permalink) Old 03-26-2012, 09:09 AM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
I agree with ktmripper on the low idle speed/near stalling being the cause of the low oil gauge.
The overheating problem could be the signs of a failing water pump, or low coolant as he suggested. Take the cap off the radiator while the car is running, if fluid runs out or isn't moving chances are the water pump is bad... don't do it when the fluid is hot...
tgikal is offline
post #4 of 8 (permalink) Old 03-26-2012, 11:38 AM
First, remove the thermostat and test and replace.
They do not last forever and the response lags when compared to new.
Flush and clean the coolant.
When idling and the temp rises,
turn the heater levers on and if the temp drops,
it may be the radiator.
Brian O
bostosh is offline
post #5 of 8 (permalink) Old 03-26-2012, 06:23 PM
wbain's Avatar
Date registered: Dec 2003
The oil pressure, when hot, will drop to 15 psi, or '1', and is normal. Once you accelerate, it will go back up to 45, or '3' on some models.
wbain is offline
post #6 of 8 (permalink) Old 03-28-2012, 03:21 AM
Date registered: Feb 2012
Vehicle: 1975 Mercedes Brenz 450 SL with 58,000 miles
I have the same problem with my '75 450SL. When I stop for a red light, it drops really
low, 5-10 and I made sure my husband put 7.5 qt. In it, found the book and books says
put in 10w40,I questioned that, as the book is 37 yrs old an things change.
Also while I here,I can't get the heat work and again using the owners manual for direction, plus is it possible to wire the AC to run all the time. I 'm afraid to mess with
because it does work, I just hate running the AC with the top down. Does anyone have any idea that could help.
SChedgie is offline
post #7 of 8 (permalink) Old 03-29-2012, 11:22 PM Thread Starter
Thanks..
I think my radiator was bone dry. I filled it up with water and believe the temp is doing better. My idle is very rough. Sounds and feels like she wants to stall. Once I take off from sitting at a light it smells like exhaust in the cab of my car. The smell dissipates until I sit for another light..smells like I'm running super rich..no mechanic here. Just trying to get logical ideas. Thanks again
post #8 of 8 (permalink) Old 03-29-2012, 11:56 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
If it was dry there must be a leak, check the lines where they connect and the length of the hoses to locate the source.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
    Engine Oil Pressure - during Idling and at low speeds Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 7 01-21-2011 10:31 AM
    1998 MAF testing voltages of idling and not idling. F 00C 2G2 025 USFloors R170 SLK-Class 1 05-30-2010 06:02 AM
    Idling rpm on an automatic – exactly what IS idling? Saloon W201 190-Class 31 02-28-2010 04:00 AM
    Oil Pressure Drops on the idling "D". racing1219 W126 S,SE,SEC,SEL,SD,SDL Class 8 02-12-2009 08:21 PM
    Is my oil pressure normal? It's between 2 and 3 when idling. azo313 W201 190-Class 2 02-02-2005 11:38 AM
