W111 M180 motor plug wire diagram? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-25-2012, 02:12 PM Thread Starter
tooshea's Avatar
Date registered: Jan 2008
Vehicle: 1985 380SE, 1966 230S, 1977 450SL
have the inline M180 6-cyl, after 15 years its almost ready to start, but I need the spark plug order b/c the car goes putt-utt-putt when it tries to start, it could be the plug wires right? please send photo or diagram if its out there. amazing in the internet age I cannot find this, but I have a team on a forum helping me rebuild it LOL
tooshea is offline
post #2 of 7 (permalink) Old 03-25-2012, 02:54 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 18 Post(s)
1-5-3-6-2-4
Dwell and points good?
Nutz 4 Benz is offline
post #3 of 7 (permalink) Old 03-26-2012, 08:12 AM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
Just an fyi, the firing order is cast into the valve cover of my engine... took me forever to figure out what the numbers meant until I really thought about it.. thought that was kinda nifty...
tgikal is offline
post #4 of 7 (permalink) Old 03-26-2012, 05:12 PM
wbain's Avatar
Date registered: Dec 2003
MB uses the same firing order for it's inline 6's.
wbain is offline
post #5 of 7 (permalink) Old 03-30-2012, 04:18 PM Thread Starter
tooshea's Avatar
I guess i need to rephrase myself, I need to find out which plug goes to which wire. All are new I just don't know how they go on the the disto. Tikiga, you have a photo of the cam #'s can you resend without the blow up please
tooshea is offline
post #6 of 7 (permalink) Old 03-30-2012, 06:09 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
Set the crank at #1 top dead center. Pull the distributor cap and notice that the rotor is lined-up with a notch in the top edge of the distributor body. Check which plug wire on the cap lines-up with the notch. That is #1 plug wire. Then follow the firing pattern clockwise on the distributor cap to determine the other wire locations.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is online now
post #7 of 7 (permalink) Old 03-31-2012, 03:47 AM
Like carenterman said find #1, also it may be marked on the cap which is #1, then clockwise from #1 is:
Cap #1 to Plug #1
Cap #2 to Plug #5
Cap #3 to Plug #3
Cap #4 to Plug #6
Cap #5 to Plug #2
Cap #6 to Plug #4
Just like the numbers on the valve cover indicate 1 - 5 - 3 - 6 - 2 - 4
I doubt it will help, but:
tgikal is offline
    W111.012 220sb M180 engine- oil pump tightening torque www.oldtimercentrum.com Vintage Mercedes-Benz 3 11-28-2011 01:40 AM
    w111 wiring diagram or help Montclair Benz Vintage Mercedes-Benz 8 10-25-2010 03:53 PM
    404 / m180: what motor oil? Two Tone Unimog 5 12-15-2007 06:31 PM
    Choice of Plug wire/plug combinations MBGraham Vintage Mercedes-Benz 2 10-20-2007 07:52 PM
    420sel wiper motor connection plug disconnected need a diagram on what pin goes where forgetaboutit1970 W126 S,SE,SEC,SEL,SD,SDL Class 5 04-02-2006 07:04 PM
