Arching on distributor cap cause idle drop? - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 03-24-2012, 07:27 PM Thread Starter
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
I am troubleshooting a miss, or dropped idle, when my car is in "drive" and stopped at a light for example. My car has Pertronix fitted and I noticed there is evidence of corroded terminals under the distributor cap. What would cause the arching, and could this be the cause of the stalling out?
If I may, the engine tends to drop rhythmically, such as...
vrrrrrrrrrrrr_drop_vrrrrrrrrrrrr_drop_vrrrrrrrrrrr r_drop_vrrrrrrrrrrrr
...so I don't think it is fuel related. The drop becomes more frequent until it dies.
I can throttle up enough to keep it from dying on me but this almost overrides the brakes. Any suggestions?
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #2 of 22 (permalink) Old 03-24-2012, 07:50 PM
Matvh's Avatar
Date registered: Jan 2011
Vehicle: 1969 280 SE Convertible
Suggestion
Check the coil and the ballast resistor
Also make sure the coil and spark ignition wires are in good condition
Matvh is offline
post #3 of 22 (permalink) Old 03-24-2012, 10:47 PM Thread Starter
DirectLA's Avatar
Quoted: 8 Post(s)
Where's the best place to buy ignition items for this car? Online or can they be sourced at local parts stores? I mean Bosch parts specifically, I have seen non-OEM parts at local shops but presume these aren't worthwhile?
-Marrs
DirectLA is offline
post #4 of 22 (permalink) Old 03-25-2012, 07:43 AM
Matvh's Avatar
MBZ Internet sits
Vintage Part Source Parts and Se
Check out these web site for a multiple of choices to purchase MBZ parts.
Do your home work with original MBZ manuals so you know exactly what part you need.
By the way, I had a similar issue with my 280.
I did the coil, ballast resistor, new cap, rotor, points, condenser, and ignition wires.
Greatly improved, but still had a little droop during idle.
I pulled a few plugs and they all appeared ok.
Frustrated, I went ahead and changed all of the plugs.
Sure enough the idle droop went away. Must have been a fouled plug?
But appearance of the plugs would never show it?
Matvh is offline
post #5 of 22 (permalink) Old 03-25-2012, 01:53 PM Thread Starter
DirectLA's Avatar
Quoted: 8 Post(s)
I replaced cap, rotor & plugs, no change. I have Bosch coil # 0 221 119 030 and Bosch ballast resistor # 0 227 901 014 as suggested to me coming in the morning and will report my results.
-Marrs
DirectLA is offline
post #6 of 22 (permalink) Old 03-29-2012, 03:33 PM Thread Starter
DirectLA's Avatar
Quoted: 8 Post(s)
Resolution: After installing the new Bosch coil and ballast resistor, the car has not exhibited any of the previous problems, it would seem it was indeed the coil.
-Marrs
DirectLA is offline
post #7 of 22 (permalink) Old 03-29-2012, 05:34 PM
Matvh's Avatar
Good Job
Isn't nice to solve an issue on a MBZ and make her run like new!
Matvh is offline
post #8 of 22 (permalink) Old 03-30-2012, 01:36 PM Thread Starter
DirectLA's Avatar
Quoted: 8 Post(s)
Indeed, these days I can think of nothing more enjoyable. I remember when I chased women, now they chase me in this car but I've already got a mistress with a smooth running inline-six, and oddly she's still a hell of a lot cheaper to maintain!
-Marrs
DirectLA is offline
post #9 of 22 (permalink) Old 04-08-2012, 04:58 PM Thread Starter
DirectLA's Avatar
Quoted: 8 Post(s)
Updating this thread, today I had the same idle drop but it has not happened since I did the coil swap over a week ago and before I did the swap it was missing constantly so I assumed that fixed it. I'm wondering if either (A) the Pertronix system in my car, or something else, is possibly causing coil failures, or (B) if it could be a simple matter of injectors need cleaned?
Further symptoms, it bogs down when I give it more than about 3/4 throttle such as going up an incline or merging with traffic. It died twice while moving at neighborhood speeds.
I also noted the oil on injector pump was very high, read on another forum from a helpful member who suggested this makes the car sluggish. I am correcting the level to see if it makes any change. What do you guys use for the pump, same as engine oil?
-Marrs
DirectLA is offline
post #10 of 22 (permalink) Old 04-09-2012, 07:57 AM
I would now check fuel pressure and volume, do a filter while there, check for old hoses, pinched lines too.
Brian O
bostosh is offline
    M103 & M102 intermittent idle drop & die NAA5550 W124 E,CE,D,TD Class 5 04-02-2016 01:05 AM
    Oil pressure drop at idle bitoy W123 E,CE,D,CD,TD,TE Class 11 09-15-2010 09:42 PM
    Idle drop exit56i95@yahoo.com General Mercedes-Benz 2 09-01-2009 03:22 PM
    Idle drop when aux fan starts triskaideka W210 E-Class 2 06-08-2009 06:20 AM
    380SLC low RPM drop in idle - video mbenzfan79 R/C107 SL/SLC Class 6 02-15-2008 05:47 AM
