Radiator fan for a 300SD. - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-21-2012, 05:51 PM Thread Starter
Date registered: Mar 2011
Vehicle: '82 300SD
This vehicle was bought used in '09.
It had and electric fan and a plastic radiator installed and worked just fine up until some rain storms in Feb '10.
Since then, the radiator was switched with a metal-type from a '78 300D we had sitting by the house, but after the electric fan shorted in Feb '10, no fan.
Since then, we've been able to use it in-town and haven't had any serious over-heating problems as long as the vehicle's moving.
But, before we take it on any longer trips, is it possible to install an engine-driven, cooling fan without much difficulty?
It doesn't look that hard to me, but the only thing I'm concerned about is the amount of space between the radiator and the front of the engine.
Thanks in advance.
bentstrider is offline
post #2 of 5 (permalink) Old 03-22-2012, 05:20 AM
ktmripper's Avatar
Date registered: Jun 2010
I can measure later today the space needed for the mech fan. If the radiator is all the way foreward you should be ok.
note. an 82 300sd does have plastic tanks.
ktmripper is offline
post #3 of 5 (permalink) Old 03-22-2012, 09:23 AM Thread Starter
Vehicle: '82 300SD
Okay, thanks.
As far as the plastic tanks go, you think it might be wise to take the '78 "metal" replacement out and attempt to find a used from a junkyard?
This metal radiator actually seems thinner than the plastic one that was OEM.
I could also upload a pic if needed of the arrangement.
post #4 of 5 (permalink) Old 03-22-2012, 02:21 PM
ktmripper's Avatar
The front of the mechanical fan is 2.5 inches from the face of the pulley. You'll probably want another few inches to clear the radiator. That radiator may work fine, I know the radiator in my 75 240d was copper and narrower in width but thicker in depth than the 300sd.
Why don't you just find another electric fan wire it in and keep driving? may be less trouble.
post #5 of 5 (permalink) Old 03-22-2012, 08:24 PM Thread Starter
Vehicle: '82 300SD
I'll have to see if I can find one that will fit onto this current radiator.
Now if I could find an exacto copy of the OEM radiator, then the easier it will be.
I'm still driving it as continual movement keeps the airflow constant.
Radiator for 300SD srsomasundaram W126 S,SE,SEC,SEL,SD,SDL Class 2 12-10-2009 03:46 PM
1979 300sd Radiator - W116 chefyong W116 S, SE, SEL, SD Class 9 10-02-2009 09:24 AM
Radiator needed for 1992 300sd Megadiesel For Sale/Wanted/Trade/Giveaway 1 09-20-2008 03:46 AM
Wanted : Radiator for w116 - (1980 300sd) StigHelmer For Sale/Wanted/Trade/Giveaway 1 04-28-2006 09:10 PM
300SD Heating problem and radiator replacement Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 09-18-2001 02:43 AM
