no turn signals or hazards - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-17-2012, 04:57 AM Thread Starter
Date registered: Mar 2012
just purchased 1979 450sl, been in storage 12 years, turn signals and hazards dont work, is there a flasher relay? and if so, where would it be?..thanks, bill
billthermos is offline
post #2 of 6 (permalink) Old 03-17-2012, 05:00 PM
Vehicle: Mercedes Benz 250/8 1970
On mine the hazards work normally but turn signals don't, the stick doesn't stay in the position and if I move it the lights keep on without flicker
Benz250Colombia is offline
post #3 of 6 (permalink) Old 03-18-2012, 05:12 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Check the fuses first. The relay is above the driver's left knee under the dash. If it has been sitting that long every fuse in the fusebox should be replaced.
Ed Mclass is offline
post #4 of 6 (permalink) Old 03-19-2012, 08:17 AM
gatorblue92's Avatar
Vehicle: 1977 W123.123 1991 W124.090
Quoted: 351 Post(s)
It may be the hazard switch itself that has failed. When it goes you lose hazards and turn signals.
Sent from my Autoguide iPhone app
1977 MB 240D 4 speed 142K - Long term project car.
1991 MB 300TE 5 speed 271K - Back on the road!
2014 Honda CR-V 33K - Wife's DD
2015 Ford F150 5K - My DD
1979 MB 280E 90K - Sold
1983 MB 240D 238K - Scrapped
1984 MB 300D 347K? - Sold
1987 MB 300E 5 speed 258K - Scrapped
1993 MB 400E 130K - Sold
1995 MB E320 - Sold
gatorblue92 is offline
post #5 of 6 (permalink) Old 03-20-2012, 01:25 PM
Date registered: Aug 2006
Vehicle: 1972 300SEL 4.5, 1971 Citroen DS21, 1995 Jaguar XJS
up under your dash , sitting horizontally on a little bracket is a black rectangular box with a 4(or 5, cant recall) pin plug, its the flasher relay, take it out and take the cover off. often cold solder joints break and these don't work. can be repaired or you can buy new.
But first, as previously suggested clean fuses and box (take the battery out and dremel/wirebrush) and then check the hazard button for operation and corrosion on the plug . also check all the lamps . when the lamps get old the plaster inside turns to powder and the bulb twists in the socket, causing the bulb to fail. good luck!
tcb323 is offline
post #6 of 6 (permalink) Old 03-23-2012, 11:34 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
You might want to migrate over to the 107 forum here. R/C107 SL/SLC Class - - Mercedes-Benz Discussion Forum Very active, with a lot of info. Read the sticky called Encyclopedia Germanica v107 to start with.
The flasher module can be a pain to get to. i had to take the instrument cluster out to get to mine for the same problem. As was mentioned above, check the fuses. Aluminum fuse, brass holder can lead to dissimilar metal corrosion. Remove one at a time and clean ends with coarse cloth like denim or canvas. Coat ends with a thin film of dielectric grease replace.
RadioTek is offline
    Hazards work, Turn Signals do not mb-maniac W201 190-Class 17 08-31-2011 04:44 PM
    turn signals (blinkers) don't work but hazards work. Rat2 W210 E-Class 0 06-24-2010 06:53 PM
    Proper behavior of Case 406 turn signals (and hazards) JeepinMike Unimog 11 07-22-2009 07:49 AM
    Turn Signals Work But Hazards Stop maddoxfotos W201 190-Class 10 07-04-2009 01:10 AM
    Turn Signals Work But Hazards Stop maddoxfotos W245 B-Class 2 06-09-2009 07:12 AM
