W108 manual transmission problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-16-2012, 07:59 AM Thread Starter
jeanro_44107's Avatar
Date registered: Sep 2007
Vehicle: '85 190D; '66 250SE; '87 M6; '06 X3;01 E46
Post W108 manual transmission problem
Hi again,
My 1966 250SE, manual on the floor, has developed a somewhat new problem: the shifter wobbles really hard, and is almost impossible to select the reverse. Any reliable source for shifter bushings, and info on how to replace them would be greatly appreciated.
Thank you,
Jean
jeanro_44107 is offline
post #2 of 4 (permalink) Old 03-16-2012, 10:49 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Check with the Classic Center in Irvine, CA. Have your VIN handy. 1-866-622-5277. OR
classicparts@mbuca.com.
Ed Mclass is offline
post #3 of 4 (permalink) Old 03-16-2012, 01:42 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
There are bushing on the shift rods at the shifter and at the transmission as well as in the shifter. You might want to check them all out on EPC before you call. The only way you will really know is to dissasemble the assembly and inspect it.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #4 of 4 (permalink) Old 03-16-2012, 08:06 PM Thread Starter
Thank you
Thank you very much Ed and Tony. I'll give them a phone call Monday morning. Meantime I'll try and see if the shifter can be disassembled in order to specifically identify the defective part. I am assuming that the car needs to be raised on a lift bay.
Jean
    SLK230 Manual Transmission Problem: Pop out of Reverse and Sloppy 1st+2nd Gear SilverGT R170 SLK-Class 5 03-06-2011 05:44 PM
    W108/109 Repair manual needed PaTaCHI Vintage Mercedes-Benz 6 10-31-2010 08:40 AM
    Just Purchased 190E - Transmission Problem & Serveice Manual 93190E W201 190-Class 8 04-15-2010 05:21 AM
    190e 5 speed manual transmission problem 190EEEE W201 190-Class 5 04-09-2009 07:13 PM
    Manual Transmission Problem msmith11 R171 SLK-Class 4 10-19-2006 02:22 PM
