W108's crooked power steering pulley?? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-15-2012, 11:13 AM Thread Starter
SignalRed's Avatar
Date registered: Jul 2009
Vehicle: 82' Euro 240D 84' 300D 01' SLK320 6 Speed Sport!
Quoted: 2 Post(s)
My 250s W108's power steering pulley sits crooked/cockied so the belt doens't exactly sit straight. Nothings is bent and went I had my belts replaced at a Mbenz specialist shop he said thats just the way they all sit in there. But..it is wearing my new belt. Is this correct? The crooked part that is..
"Continually Convincing Central Maryland that W123's are not slow.."
SignalRed is offline
post #2 of 3 (permalink) Old 03-15-2012, 08:13 PM
Matvh's Avatar
Date registered: Jan 2011
Vehicle: 1969 280 SE Convertible
Something is wrong
I would suggest in removing the power steering pump.
Inspect the mounting brackets and belt tensioner bolt.
Remove the pulley with the proper tool and inspect the shaft.
The belt alignment needs to be straight and true.
Something must be misaligned?
Matvh is offline
post #3 of 3 (permalink) Old 03-16-2012, 07:32 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 102 Post(s)
I have a related problem. My pump leaks in my 68 280S. To remove the pump, you need to first remove the pulley. (bolts securing the pump can be removed only with pulley removed first) To remove the pulley, you need a special tool and you need to remove the radiator first.
Where do I get the special tool ??????
Scoot is offline
    Power Steering Pump Pulley Noise r0nd3L W124 E,CE,D,TD Class 1 06-17-2011 03:38 AM
    power steering pump pulley removal anyone? bruca03 W123 E,CE,D,CD,TD,TE Class 2 01-10-2011 05:46 PM
    Power Steering pulley dans22 W202 C-Class 1 05-13-2008 09:06 AM
    Power Steering Pulley Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 0 12-22-2006 07:54 AM
    Crooked Power Steering Pump? wsad W123 E,CE,D,CD,TD,TE Class 1 05-04-2003 11:55 PM
