Cooling Water Thermostat Rebuild - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-06-2012, 06:14 AM Thread Starter
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 92 Post(s)
The W198 engine employs a rather unique thermostat arrangement.
Following a failure of the original unit and driven by the insanely high price quoted by Mercedes-Benz for replacement, it seemed appropriate to examine the cooling water thermostat with a view to a functional rebuild.
As originally constructed, the thermostat housing consisted of a front and rear portion encompassing a standard Behr Thomson thermostat unit and fastened together utilizing a rolled crimp formed on the flange of the rear portion. A short session on the grinding wheel removed this crimp and allowed separation of the components.
Perhaps most time consuming part of this project was the sourcing of fasteners small enough to fit the remaining flange areas so as to hold the housing parts together. Radio Shack, an old favorite for unusual parts, was able to provide machine screws and nuts (Part Nos. 64-3010 and 64-3017) in the 2-56 size that fit perfectly. Using a template to assure uniform spacing, eight holes were drilled through both flanges with a size 44 bit and smoothed with a file to provide a proper fit. The replacement thermostat itself is an off the shelf item in the standard 54mm diameter with a 180 degree opening value as available from any auto parts supplier. Notches cut in the perimeter of the thermostat using an abrasive wheel on a Dremel Tool provide adequate clearance for the fastening screws.
Following liberal application of sealant to both sides of the thermostat, the two portions of the housing are brought together utilizing eight 2-56 screws and nuts. After application of paint to restore original appearance, the completed assembly is ready for reinstallation in the car and more years of trouble free service.
ejboyd5 is offline
post #2 of 6 (permalink) Old 03-06-2012, 08:53 AM
NorCalSL's Avatar
Date registered: Jun 2007
Vehicle: '70 280S-'73 450SLC-'81 380SL-'84 500SEC Euro-'92 300SL24-'95 E320
Quoted: 22 Post(s)
You da man, very ingenius, I really enjoy seeing these kind of fixes.
Happy Motoring to you sir
dws
1973 Mercedes 450SLC (PineGreen/MahoganyLeather)
1981 Mercedes 380SL FORSALE (LtIvory/PalominoMBTex)
1984 Mercedes 500SEC Euro (040Black/BlackLeather)
1992 Mercedes 300SL-24 Signal Red/Black Leather
NorCalSL is offline
post #3 of 6 (permalink) Old 03-06-2012, 09:36 PM
Date registered: Nov 2010
Quoted: 24 Post(s)
I thought I recognized that thermostat, then a glance at your photo showed why.
Good luck with your gull wing.
....so what was the price???
Nitro88 is offline
post #4 of 6 (permalink) Old 03-07-2012, 04:03 AM Thread Starter
ejboyd5's Avatar
Quoted: 92 Post(s)
M-B Classic Center charges over $500, even with the MBCA discount.
ejboyd5 is offline
post #5 of 6 (permalink) Old 03-07-2012, 05:47 AM
Quoted: 24 Post(s)
O-U-C-H!!!
BTW, are you member of GWG, and do you guys have a good source of parts these days? I sold my gull wing 15 years ago and still have a few parts sacked away. Not much incentive to dig them out unless I knew if they were in need/demand.
(198 980 55 00 135) sold to an Austrian who restored to original showroom condition.
Nitro88 is offline
post #6 of 6 (permalink) Old 03-07-2012, 09:39 AM
Great ingenious fix
$500 ? there must be a conspiracy somewhere to extract money from the unsuspecting MBZ owners.
This is why I like the older models, fewer sealed sub-components.
Brian O
bostosh is offline
    Is Running at 95-100 C hot after a cooling system rebuild? Matt62489 W123 E,CE,D,CD,TD,TE Class 17 11-28-2009 01:10 PM
    cooling and thermostat molitar W210 E50 AMG, E55 AMG 3 04-14-2009 05:26 PM
    water pump thermostat Zé Bocaina G-Class 0 05-08-2008 12:05 AM
    Summer water pump thermostat Zé Bocaina W124 E,CE,D,TD Class 0 03-28-2008 11:26 PM
    Cooling Q's, thermostat-monovalve linked? MBeige W123 E,CE,D,CD,TD,TE Class 5 02-12-2006 01:47 PM
