Fan Belt Tensioner - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-02-2012, 01:42 PM Thread Starter
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 80 Post(s)
Fan Belt Tensioner
Some Mercedes-Benz engines (including the 198) employ a very positive screw arrangement to provide proper tension for the fan belt. As I have been missing parts of this assembly since I got my car 40 plus years ago it finally seemed appropriate to track down replacements to make everything whole. The costs quoted for M-B parts were shocking, so it became time for some creative thinking. In essence, what was needed was a threaded type device and an eyebolt (swing bolt/hinge bolt) that would extend as the device is rotated, thereby tightening the fan belt.
A few minutes spent at the local hardware store turned up a 3/8-16 coupling nut 1¾” in length and a 3/8-16 thumb screw 2¼” in length. The raw materials were in hand.
Some work with basic metal working tools reduced the size of the coupling nut at one end so that it would rotate freely around a mounting stud affixed to the engine block. The threaded interior of the coupling nut must also be drilled out to a diameter of 7/16” for a depth of approximately ¼” to accept the mounting stud. Similarly, some small grinding and drilling of the thumb screw quickly produced the functional equivalent of a commercial swlng bolt at much reduced cost.
For those considering such a repair/replacement, be advised that the purists may decry the use of a non-metric thread size, but 3/8-16 is so close to that which was originally used as to be indistinguishable, and the entire project was completed at a cost approximating 3% of that which was quoted for M-B parts.
ejboyd5 is offline
    Can we upgrade a M119 manual belt tensioner to automatic tensioner? gsxr W124 V8 400E / E420 / 500E / E500 / E60 30 07-13-2014 02:22 PM
    How to change the belt tensioner on '05 C230 K and where to buy tensioner??? Kevin Greene W203 C-Class 15 03-12-2014 01:21 PM
    85-93 2.3 belt tensioner and belt tensioner shock DUFFS3169 For Sale/Wanted/Trade/Giveaway 3 02-18-2011 08:42 AM
    Water pump automatic tensioner pulley serpentine belt tensioner Smith007 W163 M-Class 0 10-14-2009 06:29 AM
    Belt tensioner / Belt pulley info sarmstrong W210 E-Class 11 01-02-2009 02:43 PM
