68' 250s is a battery monster..wheres the leak - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-29-2012, 01:43 PM Thread Starter
SignalRed's Avatar
Date registered: Jul 2009
Vehicle: 82' Euro 240D 84' 300D 01' SLK320 6 Speed Sport!
Quoted: 2 Post(s)
Any one else have an issue with the car draining down a perfectly good/charged battery? Previous owner said it might be the clock, but it seems to drain fast..it also has a battery kill switch which I apply every night..
"Continually Convincing Central Maryland that W123's are not slow.."
SignalRed is offline
post #2 of 9 (permalink) Old 02-29-2012, 01:58 PM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Open and stuck cold start solenoid relay? Check your glove box lamp too. Does it have any non-oem add ons?
Ed Mclass is offline
post #3 of 9 (permalink) Old 02-29-2012, 03:12 PM Thread Starter
SignalRed's Avatar
Quoted: 2 Post(s)
Not that I know of but those are some good starting points! Thanks
post #4 of 9 (permalink) Old 02-29-2012, 10:02 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
Make sure no one added an under hood or trunk light that may be staying on. Even still it sounds like a bigger draw if it's running down the battery quickly, but how fast is it draining exactly, overnight, a few days, a couple weeks? How long does the car sit between drives?
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #5 of 9 (permalink) Old 03-01-2012, 05:48 PM
wbain's Avatar
Date registered: Dec 2003
With every electrical device off, pull one fuse after another and measure the current, or not, across the terminals. That will narrow it down.
wbain is offline
post #6 of 9 (permalink) Old 03-02-2012, 05:54 AM Thread Starter
SignalRed's Avatar
Quoted: 2 Post(s)
Thanks guys..I will keep you posted on my results. The battery seems to leak down within a few days. I am also suspicious of my alternator so that too might be a factor. I will do the fuse box test asap..
post #7 of 9 (permalink) Old 03-02-2012, 06:53 PM
wbain's Avatar
The alternator diodes could be bad. Check the junk yard for a modern BOSCH alternator with a replaceable regulator and brush set.
wbain is offline
post #8 of 9 (permalink) Old 03-10-2012, 01:51 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
With battery charged up, disconnect the Negative battry terminal. Place a multimeter set to measure Amps (start on the highest scale- If you have 10 Amp and 1 Amp scale, start on the 10 Amp). Make sure you have the doors closed (not courtesy lights), the key off, and any lights turned off. You should have at most 150 to 300 milliamps draw, usually the clock draws less than that.
If you have much more than that (and it sounds like you will), you will need to isolate the guilty circuit. Start pulling fuses one at a time and replacing them until you find the circuit that is causing your drain. Pull a fuse, check the meter, replace fuse if no change in draw. If your fuse box is inside, you'll have to first pull the fuse for the courtesy lights, so you won't be chasing around in circles when you open the door.
If you are going to work on old vehicles, a decent multimeter is is a must for dealing with electrical problems. Depending on your vehicle, you might want to get one that includes a dwell function if you have a point type ignition. Just don't get the $3.95 Harbor Freight special. You want something that will be useful for longer than 15 minutes.
Scott
RadioTek is offline
post #9 of 9 (permalink) Old 03-11-2012, 08:27 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
Have you had the battery tested? When the car is running, what is the voltage on the battery? When the car is off, what is the voltage on the battery? If the voltage on the battery isn't a couple volts higher running than off then I would suspect the alternator diodes - the battery isn't getting charged. If the alternator is doing its job then I would go through the fuses and see what circuit is drawing current.
Scoot is offline
    Leak, blower fan stays on and dead battery... A930Rocket W251 R-Class 6 02-09-2011 04:03 PM
    Wheres the power!? Spadwaller W210 E-Class 15 02-08-2011 02:52 AM
    220 cdi strange electrical leak and dead battery after a night dPete W203 C-Class 1 12-05-2010 05:32 AM
    wheres the sticky of the pic-ies on all of your SL(c)'s ?? Diego97 R/C107 SL/SLC Class 3 08-14-2010 04:27 PM
    Wheres My Gallery?? dodgy geezer W140 S-Class 1 01-15-2007 03:28 AM
