Right sided mirror - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-28-2012, 10:25 PM Thread Starter
tewfiks's Avatar
Vehicle: Many MBZ, Couple of 911s, couple of pick ups
Quoted: 49 Post(s)
Post Right sided mirror
Hello,
I am searching for the proper location for adding passenger side side mirror to my 1972 280se 4.5. I have looked for any reference of attachment points and have not been successful. Would I drill the new holes in the same place as the driver's side?
Thanks in advance for any insight on this issue.
Sherif Tewfik
70 280 SE/cab
72 280SE 4.5
78 6.9
80 280 SL
88 300 CE
91 420SEL
94 E500
95 E420
95 E320 Cab
95 E320 Wagon
05 E55 Wagon
07 GL320 CDI
tewfiks is offline
post #2 of 7 (permalink) Old 02-29-2012, 08:47 AM
NorCalSL's Avatar
Date registered: Jun 2007
Vehicle: '70 280S-'73 450SLC-'81 380SL-'84 500SEC Euro-'92 300SL24-'95 E320
Quoted: 22 Post(s)
Right Side Mirror
I plan to add the same to my '70 280S. I am going to place it exactly like the driver side as I too have seen no reference to the contrary.
dws
1973 Mercedes 450SLC (PineGreen/MahoganyLeather)
1981 Mercedes 380SL FORSALE (LtIvory/PalominoMBTex)
1984 Mercedes 500SEC Euro (040Black/BlackLeather)
1992 Mercedes 300SL-24 Signal Red/Black Leather
NorCalSL is offline
post #3 of 7 (permalink) Old 02-29-2012, 10:07 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
Sit in the driver's seat and have someone hold the mirror where you intend to install it. Does the vent window obscure the mirror? I'm not sure on a 108.
Scoot is offline
post #4 of 7 (permalink) Old 03-16-2012, 09:30 PM
AtlanticStar's Avatar
Date registered: Mar 2012
Vehicle: 220SEb
... this is an excellent tip!
Also, do not necessarily follow the body lines with the base of the mirror - as this could result in a placement where the mirror does not adjust to function (as on my passenger mirror ). Make sure you can see in it before you bolt it on!
AtlanticStar is offline
post #5 of 7 (permalink) Old 03-16-2012, 09:59 PM
Vehicle: 2005 SL 55 "k" 26K 1967 250 SL ?K 1984 500 SEC 242K http://www.flickr.com/photos/mercebman/
Quoted: 15 Post(s)
On a sl it is 1.5" forward of the driver side mirror. But the advice to size with help sounds best.
hilld is offline
post #6 of 7 (permalink) Old 03-17-2012, 11:02 AM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D, 1988 300SEL, 1991 300TE
Quoted: 2 Post(s)
I had the same question for my '73 220D. Some vehicles had the right side mirror on the fender well in front to the door while others have it on the door approximately in the same location as the left.
I did a quick google search for images and found most of them don't have a right side mirror but I did find his one which has it on the door about the same location as the left side mirror.
WARNING - this is a sad and sorry sight, it is not for the faint of heart. Scroll through the images to see the left and right mirrors.
<http://www.vehigle.com/vehicle-detail/1972-MERCEDES-BENZ-280SE-ZyuoAoVHyyouHAPncAV>
Good luck,
Frank
frankflynn is offline
post #7 of 7 (permalink) Old 03-17-2012, 11:08 AM
frankflynn's Avatar
Quoted: 2 Post(s)
I just felt too bad about that last photo - we cannot let that stand as an example 280se.
This page has dozens of them each one 1,000 times nicer (that doesn't take much) and several of them do have right side mirrors. One has an additional mirror on the fender but I don't think this was stock. This page will ease the pain the last image caused.
Flickriver: jenskramer's photos tagged with 280se
Good Luck,
Frank
    2005 S class wing mirror - is a 2002 mirror the same?? alpinemotorsport W211 E55 AMG, E63 AMG 0 07-14-2010 02:50 AM
    Best Way to remove double sided tape Eesjunin W203 C-Class 6 04-18-2008 10:22 AM
    Looking for a double sided Ahesive tape... sstomcat W163 M-Class 4 08-07-2006 02:52 PM
    ? for 32AMG owners. Is your rear spoiler bolted on to the trunk, in addition to double sided tape? LelloSLK R170 SLK-Class 1 09-11-2002 09:07 AM
    Drew...where did you buy your 3M clear double sided mounting tape? cgeorge430 W163 M-Class 2 09-10-2002 10:35 PM
