Engine out of car - what to replace? Subframe mounts + ???? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-23-2012, 05:14 PM Thread Starter
Scoot's Avatar
Date registered: Oct 2002
Quoted: 118 Post(s)
I have a 1967 250 S that has no engine/trans. I'm going to be installing the engine/trans from a 1968 280 S. Since the 250 S has nothing in the engine compartment right now, I think it's a good time to replace things that are easy to get to. Here is what I can think of - I would like other suggestions:
1. Subframe mounts
2. Motor mounts
3. Trans mount
What else? Also, I looked for the subframe mounts in the Big Blue Book and didn't find it... I'm looking the wrong place - where is it?
I found a nice writeup here:
PeachPartsWiki: DIY 108 Chassis Sub-frame Mounts
thanks
Scott
Scoot is offline
post #2 of 3 (permalink) Old 02-23-2012, 05:28 PM
wbain's Avatar
Date registered: Dec 2003
Yes, you need to replace those parts. Check the steering linkage including the idler arm. Get a rebuild kit and make sure you grease it after it's repaired.
Grease all the suspension joints and you may have to use a heat gun to heat the joint to get the grease to flow.
Check the inner control arm mounts to make sure the rubber seals are OK. If not, wait until you install the engine. You need to engine weight to help take the lower control arm off and get it back on.
Get a new flex disc too. There is a grease joint at the front of the driveshaft.
wbain is offline
post #3 of 3 (permalink) Old 02-23-2012, 11:30 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
On the engine itself, remove the exhaust manifold and replace the seal. MUCH easier with the thing out! I'd also look at replacing the water pump (or inspecting it) and pressure testing the radiator.
Grubeguy is offline
    Time to replace engine mounts... amstel78 W123 E,CE,D,CD,TD,TE Class 10 06-09-2011 06:58 AM
    How do I replace engine mounts on W108 - 280 SEL 4,5? 280SEL4,5 Vintage Mercedes-Benz 1 05-31-2011 09:59 AM
    how do you replace transmission mount and engine mounts on 2003 s600? 2003 s600 W220 S-Class 1 04-16-2009 12:09 AM
    Replace Engine and Tranny Mounts nalonge W124 E,CE,D,TD Class 18 03-14-2007 02:06 AM
    replace rear subframe mounts - DIY or not DIY? philthompson W126 S,SE,SEC,SEL,SD,SDL Class 1 02-02-2007 07:40 AM
