74 450SL - Cold idle hi/low/hi/low cycling - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-20-2012, 08:39 PM Thread Starter
Date registered: Feb 2012
Vehicle: 1974 450SL 116K Miles
Hi all, brand new owner of this vehicle. 116K miles.
After it's warm, idles well, but when starting, it idles hi/low cycles every 1-2 seconds. Seller mentioned idle control valve. I have a feeling this is a well-known symptom.
I appreciate any responses and thank you in advance!
mejojo is offline
post #2 of 4 (permalink) Old 02-21-2012, 08:33 AM
Logikal's Avatar
Date registered: Dec 2011
Vehicle: 1974 450SL; 2009 CLS550
Head over to the 107 forum and check the sticky for Encyclopedia Germanica.
Tell tale signs of an Aux. Air Valve
Logikal is offline
post #3 of 4 (permalink) Old 02-29-2012, 10:48 AM
Peoria Benz's Avatar
Date registered: Jul 2006
Sounds like the air valve to me. I think they are getting harded to find (and more expensive). Anyone had any luck freeing up sticky valves?
Peoria Benz is offline
post #4 of 4 (permalink) Old 02-29-2012, 03:20 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
Can't say I've ever had a sticky valve, but if memory serves, a good soak in acetone (nail polish remover) followed by another one in WD40 or other penetrating oil does the trick. Try a general search in this forum - I seem to remember hearing about this before...
Grubeguy is offline
    Hard start (esp. when Cold), low idle-- Idle Control Valve? Erwin8r W124 E,CE,D,TD Class 17 08-31-2012 09:22 AM
    74 450sl cold idle surge wvbenz R/C107 SL/SLC Class 5 09-30-2010 04:42 PM
    Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-22-2010 11:28 PM
    450sl High Cold Idle houston14 R/C107 SL/SLC Class 10 05-20-2009 05:31 PM
    Help! Normal idle when Cold/ High idle when Hot VicsBenz W201 190-Class 20 03-23-2007 08:58 PM
