Oil leaking from top bolt on filter housing - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-13-2012, 12:59 PM Thread Starter
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
On my W111 I noticed a leak at the top bolt on the oil filter housing, this is not the bolt you undo to remove the housing on the bottom. In my schematic I see the bolt has a spring inside and a couple other bits, I'm curious if I can tighten it down or does it need a certain "setting" or position since the spring is in there, and what does this bolt do anyway? My searches all brought up the bottom bolt as the topic.
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #2 of 2 (permalink) Old 02-24-2012, 12:34 PM Thread Starter
DirectLA's Avatar
Quoted: 8 Post(s)
Wanted to update this thread as I was told on another forum that this bolt is for an oil bypass and the small leak is caused by simply being loose or that it needs another crush washer.
-Marrs
Last edited by DirectLA; 02-26-2012 at 11:15 AM. Reason: Updated with resolution to problem
DirectLA is offline
    38mm bolt on oil filter housing? Espresso W202 C-Class 2 12-03-2012 05:17 PM
    Bolt on oil filter housing loosen but craigbern W140 S-Class 15 01-14-2012 04:58 PM
    Please Confirm Oil Filter Housing Bolt Sizes Bengoshi2000 W123 E,CE,D,CD,TD,TE Class 1 01-13-2012 01:29 PM
    M112 240/280/320 oil filter housing retainer bolt size stevesey W203 C-Class 0 06-14-2009 01:10 PM
    HELP! Oil Filter Housing Bolt Broken 500ezin W123 E,CE,D,CD,TD,TE Class 7 11-16-2007 01:41 AM
