Alternator adjuster bolt with gear sprocket - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-08-2012, 10:25 AM Thread Starter
Date registered: Feb 2012
I'm working on this 1978 280E Alternator and there is a special bolt for adjusting the belt tension on the alternator. The gear/sprocket on one end of the bolt is stripped and trashed. Are these bolts available or do I have to go search a junk yard for a good one?
None of the alternator bolts have washers either. The pivot bolt has lots of slop too. Either the aftermarket alternator pivot hole is too big or there should be some bushings on the bolt. Anyone have a exploded view of the alternator and its hardware and bracket?
steuspeed is offline
post #2 of 4 (permalink) Old 02-08-2012, 10:51 AM Thread Starter
Found a pic. Looks like I need one lock washer and one flat washer and a new star bolt. I see no washer on pivot bolt. Not sure where 46 and 149 go.
post #3 of 4 (permalink) Old 02-15-2012, 06:36 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
A couple of years ago, I bought one from my MB dealer for a 280C with a M110.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #4 of 4 (permalink) Old 06-16-2012, 05:59 PM
kahlil88's Avatar
Date registered: Dec 2009
Vehicle: 1985 Mercedes-Benz 190D 2.2 (717.411 5-speed)
Quoted: 27 Post(s)
I ran into this problem when I got my 1978 300D. The bolt was super hard to find and unfortunately my adjustment track was also stripped so I tighten it past a certain point. I'm hoping it's possible to upgrade to the newer and more common style with the "L" bolt, otherwise I will have to wrestle on a new belt that will have to be replaced again in a few months.
This is what you're looking for though: 1101500372 alternator Clamping Bolt...geared tension adjuster bolt
Based on the part number, I believe it originated in the W115 models.
Wanted
W201: Late model cladding clips, mushroom leather seat covers
For Sale
W123: Parts from 1982 300TD wagon
W201: Signal lamps, SRS airbag, mushroom rear seat
kahlil88 is online now
    300TD missing alternator adjuster nut Kyohe W123 E,CE,D,CD,TD,TE Class 7 10-29-2011 01:44 PM
    Alternator Bolt DP W201 190-Class 4 08-21-2009 06:21 PM
    Little adjuster bolt near water pump rob76 W124 E,CE,D,TD Class 11 06-28-2008 08:29 PM
    1995 S320 Camshaft Adjuster Gear Alignment tmlarch General Mercedes-Benz 1 03-30-2008 05:37 PM
    Alternator Bolt Servord W126 S,SE,SEC,SEL,SD,SDL Class 2 01-26-2005 12:35 PM
