Thinking of buying a 1971 350 SL - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-08-2012, 07:16 AM Thread Starter
Date registered: Feb 2012
I drive a simple MG and have been looking at a 71 350 SL. It's described as a VIN 107 chassis, full European specs, 3.5 liter V-8, 4 speed manual transmission. Given the simplicity of my MG (76 Midget), what might I be getting myself into with this car? Mileage is unknown. It's had recent brakes, exhaust, throttle and shift linkage bushings, fuel pump, battery, and tires. The car looks solid...I have not driven it yet. What should I be looking for? I've heard the fuel injection can be tricky and that diagnostics are difficult because the computer technology has moved on. I've also heard that wiring is critical with the fuel injection. Any tips would be greatly appreciated.
mjj3m is offline
post #2 of 2 (permalink) Old 02-15-2012, 06:46 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
The injection system is not all that complicated and is well-documented. You are correct that the wiring that connects the various sensors to the brain needs to be in good condition. In addtion, there are two components, the Manifold Air Pressure sensor and the trigger points that can be expensive to replace. Be sure to check the car from cold start through warm-up because that is where problems will be most obvious.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
    Considering buying a 1971 220D... rkcreative Vintage Mercedes-Benz 5 04-26-2011 05:05 AM
    Thinking of buying a SL What to look for jimbo409 R129 SL-Class 13 11-08-2010 12:33 PM
    Thinking of buying a ML (UK) Chris Souch W163 M-Class 2 01-07-2010 05:05 AM
    Seriously Thinking of Buying Hoser48 W204 C-Class 0 10-10-2009 06:28 PM
    For all those thinking about buying an SLK... Philip Pickett R171 SLK-Class 11 10-19-2005 04:02 AM
